connieflyer
- Aug 23, 2012
When you get the amp and have had some time with it perhaps you could do a review for the rest of us, sounds like something I might like to have myself. Thanks
It will be able to use two C3G's as drivers or just a single 6/12/25 SN7 as a driver ...32 ECC ....ect.......................also will be able to use 6F8G with Glenns adapter....plus many more...too many to list
The rectifier is PY500/42EC4A and are really cheap, and Glenn says they are better than any 5 volt rectifier....so this is really sweet.
Power tubes can be 6AS7G.....7236....6080.....6336 for low impedence cans....also has a switch for running 5998 at it's full potential.
Really looking forward to it.
Very sweet. Did Glenn give you a dynamic range on that baby? Is it high impedance only or can you run Grados and the like?
Is this one of a kind, or are there impressions of the amp? Just wondering how Glenn's amps are voiced. Seems it should bring out the 650's sound nicely.
Okay I will chime in with the third question, where can we view, see, drool over, or compare these
Just unboxed my HD 650's and, while they do sound nice, I was expecting them to sound considerably better than my PC 363D headset. This is going to be a stupid question, but should I get an amp? I'm currently just using my PC motherboard which has a built-in amp for up to 600 ohms but it doesn't really get as loud as I would have thought. I was looking at the JDS Labs O2+ODAC for a decent option (will post in that thread as well). Would that do a good job of really powering these headphones or am I out of luck due to the open-back design? The sound is great (and was on the PC 363D's as well) but I feel like I need one more notch on the volume knob that isn't there. I think I could easily get the sound I want from closed-back headphones but I don't like the feeling of pressure that they put on my ears and prefer open-back headphones by far. Thanks for any input on my stupid question; I just don't want to drop ~$300 on an amp with no appreciable difference.
