olor1n
The Man. The Myth
- Aug 26, 2010
You can't listen to a spec sheet.
Is that how you buy things? Ignore the specs?
What do you hope to achieve here?
I've got the dx50. It is not enough to drive the 650. The amp portion is somewhat of the weak link in this otherwise fine dap. Paired with a decent portable amp, I think that you'd do pretty well with the dx50 and the 650. I don't know anything about the amp that you mentioned though.
In that case I'll increase my budget to $600 however I have some DAC and AMP in mind.
First off, my guy told me to just upgrade the tube of my Bravo Ocean and he says it would increase the sound quality significantly, he said the stock tube can already surpass the quality of my PB 2. For my DAC I use a Go Vibe cheap DAC which is adequate if you never own a DAC before however I really wan to upgrade it as it's my weakest component of my PC rig.
For DAC I had the Aune T1 or X1 in mind which I heard it's quite good and also somewhat cheap, however I am planing to up that later to a matrix-i DAC and for my AMP after I up the tube I can lastly go from that to a La Figaro 339 Dark Voice 2013 wich looks great and sounds great from what the reviewers said.
I would still like to see more suggestion bear in mind my budget is'nt fixed and I can go higher as long as I am happy with the item and think it has good value.
Thank You.
This is the amp I mentioned, it should drive my HD 650 but I am just wondering if it's gonna synergize well or not.
Your DX50 and PB2 are iBasso. Why not get the DB2 and make a balanced triple stack? I haven't heard any iBasso stuff, but have read plenty of their synergy with each other...
When it comes to tube amps I will repeat my self again ..upgrading tube makes the biggest difference ,re-cap second
I have Aune T1 and Shiit modi and both are very close in performance all tho I like the Aune T1 smoothness and ability to throw third tube in to the mix amd sometimes I listen via modi so I only use the tubes from my OTL,..if I was you I would just wait and save you $ for the the amp/DAC of your choice (like DV339 you mention ) otherwise you keep spending money on something you end-up selling anyway
Yeah good points but wat do u mean I can add a third tube to the Aune T1 when it has only one? I believe the DV339 is amp only and also I dun mind just upgrading the tube of my Ocean Bravo then the next one would be DV339. As for DAC I am still torn between Aune T1 and X1 the price difference is about 60USD.
I was just saying that with my OTL I can use three tubes (1 on Aune+2 more on OTL)
P.S. Aune T1 sounds marvelous ,there is no sibilance and can use a LOT of tubes but I don't think it would be night-day upgrade over Bravo ,try different tube on Bravo first
OTL?
If you want high fidelity sound then specs do matter . If you want a personal flavour of sound then they don't .
