Anderosai
- Feb 27, 2011
I have the Sennheiser HD600s. I have two questions :
1. This just happened no more than an hour ago - the audio is randomly cutting out of the left / right headphone. I have narrowed it down to the connectors that go into the headphones. I'm not sure if it's the plugs or the socket though. What has happened is that the contacts are sensitive to position. What can I do to fix this/
2. I would like to know if it's possible to get a braided headphone cable .. or whatever it's called , where instead of just having plastic and the wire it has the shealth around it - I'm not looking for the "improvement" you get from higher end headphone cable , just higher quality then what's provided.
Thanks.
Thanks.
