Lan647
Sorry I can't say much about the portable desktop amp as I have not heard the combination. But spec wise, it does look up to the task. I would PM aimlink and see what he thinks as I believe he owns that amp/dac.
If you need a portable solution, you would be hard pressed to find any better. Now if you can live with a desktop only solution, I would suggest that you look into tube amps as they match very well with the HD800s. A Woo6 or MAD tube amp + desktop dac would also go a very long way IMO.
Yes, please do so.
Yes it reached my ears that the HD 800 matches well with tubes, though I won't start off with a tube amp. I mean the headphones are (or... will be) there, and I have time to upgrade my equipment multiple times, so one day I might get myself a tube amp. Money doesn't grow on trees, though - which sucks...
