TheGoodGoodMan
- May 4, 2014
Hi.
In Propellerhead Balance sound interface headphone outputs specification i can't find anything about how many Ohm it can support. Only Data that is available is:
So my question are:
Do i need headphone amplifier or Balance sound interface is sufficient to handle HD 600 headphones?
How can i tell that headphones are "under powered"? Is it just volume or quality of sound as well?
If you need full Balance specification sheet you can find it here:
http://www.propellerheads.se/products/balance/index.cfm?fuseaction=get_article&article=measurements
Headphone Outputs
Maximum Output Level
+9.6dBuSNR
-103dB (A)THD+N
0.005% @ -4dBFS. 1kHzFrequency Response
20Hz to 20kHz, +/-0.5dB @ 48kHz sample rateSo my question are:
