ArneH
- Dec 14, 2015
In my opinion the original is the best. I have heard it at a friend and was slightly better than my HD450. Later I bought a HD480 II which wasn't good at all.
Now I am hooked on my RS-117 with a silver 6,3 Jack (it's not good if you put on a gold one, because the 3,5 is already a gold one) but someday hoping to get an RS-185.In my opinion the original is the best. I have heard it at a friend and was slightly better than my HD450. Later I bought a HD480 II which wasn't good at all.
How about the 480 Classic and 480 Classic II compared to the HD 480 and HD 480 II?In my opinion the original is the best. I have heard it at a friend and was slightly better than my HD450. Later I bought a HD480 II which wasn't good at all.
I didn't compare them but I think the original is hard to top.How about the 480 Classic and 480 Classic II compared to the HD 480 and HD 480 II?
As someone who seems to have used most, if not all models of the 480, which ones did you find to be the best?A picture of my beloved Sennheiser HD 450s and 480s:
from right to left:
Sennheiser HD 450 (70 ohm)
Sennheiser HD 450 II (60 ohm)
Sennheiser HD 480 (70 ohm)
Sennheiser HD 480 II (60 ohm)
Sennheiser HD 480-13II (600 ohm)
Sennheiser HD 480 Classic (70 ohm)
Sennheiser HD 480 Classic II (100 ohm)
Sennheiser HD 480 II Level Limited 88dBA Canford (1700 ohm)
Sennheiser HD 480 II Level Limited 93dBA Canford (1700 ohm)
If there is any further model available, please, let me know.
The classic one. 4th from the left.As someone who seems to have used most, if not all models of the 480, which ones did you find to be the best?
What elements in particular did you find that they were able to do better? Was it a big margin, or just a slight difference?The classic one. 4th from the left.
I am a huge fan of vintage ortodynamics. The classic stands closest to them. Plain, uncolored, honest sound, best midrange. So my pick is the classic ver1. But is just me with my partial opinion.What elements in particular did you find that they were able to do better? Was it a big margin, or just a slight difference?
I managed to pick up a pair of classic mark 1's, quite a nice sound so far, and a surprising amount and depth of bass from something so light! Bit weird for me as I only have circumaural headphones, but I'm sure I'll get used to it.I am a huge fan of vintage ortodynamics. The classic stands closest to them. Plain, uncolored, honest sound, best midrange. So my pick is the classic ver1. But is just me with my partial opinion.
Hello. I have just bought a pair of Classic ii as I am curious to how they sound etc so once I have them I may be able to see what the alternatives in terms of earpad replacements. How do yours sound? Do you have any other vintage headphones to compare then to? Thanks.I managed to pick up a pair of classic mark 1's, quite a nice sound so far, and a surprising amount and depth of bass from something so light! Bit weird for me as I only have circumaural headphones, but I'm sure I'll get used to it.
Only problem is that the original earpads on these have totally disintegrated, and there's a cloth covering wrapped over the back of the earcups to make them useable.
The only place I've managed to find that sells replacements is the canford audio site. I dont suppose you, or anyone else, happens to know of what other options for pads might be available?
Was hoping to find some third party/chinese options, and there's only basic sponge wrapping type things there that I can see. Only other idea I've had is seeing whether I could possibly find a circumaural earpad that would fit, or could be adapted to fit, though I expect that would have an impact on the sound... if not, I suppose I'd have to try and pick up a second pair to use the pads from them
https://www.canford.co.uk/Products/54-4005_CANFORD-LEVEL-LIMTED-HEADPHONES-HD480-Spare-earpad-pairHello. I have just bought a pair of Classic ii as I am curious to how they sound etc so once I have them I may be able to see what the alternatives in terms of earpad replacements. How do yours sound? Do you have any other vintage headphones to compare then to? Thanks.
Hi, I have some hd 450 red not the black s version, what is the difference ? Just curious after seeing yoursI have the same collection. My new acquisition - Sennheiser HD 450S (60 Ohm).
And what I'm looking for:
Sennheiser HD 450 II (turquoise)
Sennheiser HD 450-13II (600 ohm)
Sennheiser HD 480 II Level Limited 85dBA Canford (1700 ohm) (green ring)
And I hope these are last three...
Sorry for late post but maybe you want to know about another models.
Did your classic II ever turn up? What did you think?Hello. I have just bought a pair of Classic ii as I am curious to how they sound etc so once I have them I may be able to see what the alternatives in terms of earpad replacements. How do yours sound? Do you have any other vintage headphones to compare then to? Thanks.
