I currently own both the Amperior, the Audio Technica M50x and the Shure SRH840. If you're strictly looking for portable use, I would go with the Amperior. It isolates very well, and is a real pleasure to use in noisy environments. To be honest, the Amperiors didn't WOW me out of the box. What's more, I've owned them for a month and until only last week I decided to keep them. If you end up going with them, bear in mind that clamping force can be an issue (it almost made me give it back). Sound-wise they have a very forward sound signature that can be a bit too aggressive and fatiguing. For me, the comfort and sound issues were solved when I changed the pads to the ATH SJ5 pleathers.
At home, I use the srh840. Isolation is also very good . Comfort was also initially an issue due to the heavy headband, but over time I've become used to it. The sound is neutral /warm and it's quite pleasant to listen to for extended periods of time (at a low volume).
The M50x I ended up giving them to my father as present, given that the other two are better for my tastes.
I have all three...
I would rate them: HD25-1 > Amperior > M50X
Technically the m50x are probably better but if you ask me what makes me want to move to the music, it's the Senns. Dynamic, energetic, punchy, clear and engaging...
Cheers,
K
I am really sorry for all the bother but i really need some help on choosing my next headphones....
A couple of months ago i sold all my headphones but i am now wanting to buy 1 or more pairs...
So here's the deal... i am a guy who mostly listens to pop, rock (artic monkeys, biffy clyro, maximo park), indie and alternative (stuff like metronomy and James Blake, Bon Iver), and edm (specially prog and old schoold tiesto trance)....
My favourite headphones so far are the ath m50, the hd25-1 ii, cal! and the first gen of the over ear momentums (i loved them but they had small pads....)....
Right now i am thinking of a couple of options.... The headphones that i am considering right now are the new wired over ear momentum 2.0, the audio technica ath m50x, the beyerdynamic dt770 in the 80ohm version and the legendary sennheiser hd25 1-ii....
So Heres my dilemma.... I want to be able to make the best choice possible and i want you guys to share your opinions on this matter...
I am a guy who likes versatile headphones and i usually choose the best bang for buck.. Usually i use portable sources and i like my headphones to be easy to drive (but i also already got a topping nx1 so i think i am covered for now in terms of amolification), and i usually also like to be able to use them anywhere...
I loved the first gen momentums and i am pretty sure i would like the 2.0 over ears.... They would suit me as home and outside cans but the truth is that at their current price i can for not much more money buy all the other 3 options i mentioned....
Never tried a beyer headphone but i am pretty sure the 80ohm is the one for me because of they seem to have a similar sound sig to the m50s than all the other dt770 versions....
The hd25, had them land loved them.... They clamp yes but the sound is still amazing they are great al rounders and they were a very nice compliment to the 1st gen over ear momentums.... Inhad the amperiors but did not like the weight of the cups and the sound of the hd25 was kind of ruined.... Big bass and softer mids and highs that were almost drowned by the bass...
The m50s at the time i liked the bass but i did not like the unnatural and thin treble combined with the recessed mids and weird pads.... But still i admit that the sound was overall pretty good...But right now they seem to have much better pads and the swapable cables makes them an option to use anywhere...
So what do you guys recomend me?
Do i buy the 2.0 over ear momentums only and settle with just 1 pair for all purposes (are they better than a combination of any of the other mentioned headphones?)?
Do i make a dt770 80 ohm + hd25 or m50x combination (or other combination) for home and outside use?
Are these worse, at the same level or better than the momentums 2.0 in terms of sound quality? can i consider even buying all three and have headphones for basically the rest of my life...? biggrin.gif
Its a confusing choice i know but i would like very much to read your coments on this matter....
Cheers....
