Sennheiser connector problem
Jun 21, 2013 at 3:17 AM Thread Starter Post #1 of 6
jakobmagnusson
Hi there,
I have two pairs of Sennheiser headphones:
- Sennheiser HD 25-1 II (on the move)
- Sennheiser HD580 (at home)
I'm very happy with both, but unfortunately I have a connection problem with them. It seems their is a connetion problem in the connectors, in the "speaker" end. In swedish the word is "glapp", I dont know the proper English word but sometimes it works perfect, and suddenly it's a disconnetion. And when i touch the cable/conenctor, it works perfect again. I don't think it is in the cable but in the connection (I bought a new cable for HD 580). Quite annoying... I tried usin "contactr spray" (again, I dont know the proper English word..), but not improving really..
Known issue with Sennheiser?
What to do about it?
(Have tried to search the forum, but not found anything, maybe I'm using the wrong wrods..)
Regards,
Jakob
Jun 23, 2013 at 1:46 PM Post #3 of 6
Hi,
Found some interesting reading:
http://www.instructables.com/id/Sennheiser-HD25-1-Diagnose-and-Repair/
http://jwsoundgroup.net/index.php?/topic/9097-sennheiser-hd-25-ii-intermittent-signal-issue/
Havent tried any tips yet...
Regards,
Jakob
Jun 23, 2013 at 3:10 PM Post #4 of 6
dISMANTELD ALL THE WAY TO THIS LEVEL:
http://www.instructables.com/files/deriv/F77/ZVHW/GI0TKDV4/F77ZVHWGI0TKDV4.LARGE.jpg
used contact spray on the springs. I think the springs should make contact to both the connector and the "post" where the thin cable to the coil is fastened. Maybe it is the spring - post that is getting corroded? Then it might being better to spray from here, ratehr trying to get some down the small holes?
It works ok now, but  Ineed to use it some days before I can say it is solved...
Comments or thoughts are appreciated.
Regards,
Jakob
Jun 26, 2013 at 12:59 PM Post #6 of 6
Regards,
Jakob
It lasted for 2 days, it started to crack again..
Would it make difference to remove the spring and phusically use contact/spray alcohol to clean it??
/Jakob
