PFKMan23
- Dec 31, 2004
[size=x-small]I recently had the opportunity to pick up an Apuresound cable and compare it to the Enigma Audio oracle cable. The reason why I wanted to try these two cables was because I was curious about the discussions surrounding the V3 cable and given my positive experience with Enigma Audio cables in the past, I also wanted to see what his more recent offerings were like. Given that they have similar components, i.e.: copper/silver combinations, I figured this would an interesting choice.
The test system was as follows:
SACD Mods Sony SCD-C555ES --> Parasound D/AC1600HD --> Rockhopper Balanced B22 --> Sennheiser HD580 with APS V3/Enigma Audio Oracle Cable[/size]
[size=x-small]NOTE: I am running the amp single ended for this comparison because the APS is a single ended cable[/size]
[size=x-small]Pricing:[/size]
[size=x-small]Apuresound V3 Cable - $260 ($240 for the bass length of a 9' cable and $20 more for the Sennheiser Cardas connectors) - APureSound - Where The Music Is Always Pure - APS Audio LLC.[/size]
[size=x-small]Enigma Audio Oracle M Cable - $225 for a 2.5m cable with one pigtail - http://www.enigma-audio.com[/size]
[size=x-small]Track 1: Eric Clapton Unplugged – San Francisco Bay Blues[/size]
[size=x-small]The first difference that I noticed was that with the V3 cable the soundstage seemed more closed in, in comparison to the Oracle cable which seemed more open. The APS V3 was overall a drier sounding cable with less body than the Oracle cable. That said, both seemed to have very good clarity with very comparable, midrange, bass and treble. However, I feel the Oracle exceeded it, because of the increased body that the song had, which seemed to give it more liveliness.[/size]
[size=x-small]Track 2: Rancid And Out Come the Wolves - Journey to the End of the East Bay[/size]
[size=x-small]I use this track mainly to test and compare bass as this song has a really nice bass line, using the bass guitar. In this case, both cables seemed to yield fairly similar results, the bass was articulate in both cases, although I feel the APS V3 cable performed slightly worse due to the more closed in soundstage that it presented. It was also rougher sounding than the Oracle which was slightly more refined.[/size]
[size=x-small]Track 3- Josh Groban Josh Groban – To Where You Are[/size]
[size=x-small]I like this song due to the body that Josh brings to his music when he sings. Both performed very similarly, however there were a few notable differences that I noticed. This first difference occurs where Josh sings the high G. The Apuresound cable had slightly better clarity, however while singing the high G, the Apuresound cable seemed to yield a screechy note that I have found more apparent in lower level systems. The other apparent difference that I found is near the end of the song, I feel the Oracle cable better reproduces the decay that is apparent in Josh’s voice. To me that is significant because when this decay is absent, it almost acts like a roll off like I have found in the earlier serial number K701s.[/size]
[size=x-small]Other remarks:[/size]
[size=x-small]The APS V3 cable is a lot thicker than the Enigma Audio Oracle. Consequently, it is also more stiff. The only headphone cables I have encountered that are more stiff than he V3 are the V1 Zu Mobius and the Moon Audio Silver Dragon. The cable I tested used the standard carbon techflex. I have asked around and it seems that super nylon sleeving addresses this somewhat. However, I have not been able to confirm this for myself. That said, both cables are well built and backed by their makers.[/size]
[size=x-small]Concluding remarks:[/size]
[size=x-small]Overall I feel both are very good cables. However, given the stiffness of he V3 cable a well as the more closed in presentation, I feel the Oracle is a superior cable.[/size]
