DangerClose
- Feb 26, 2013
There's the different ohm ratings, and then Pro or Premium. Premium has the nicer grills, non-coiled cable, and a lighter clamp. The only sound difference for the same ohm rating is any difference from the clamping force and possibly if the grills make a difference from letting more or less air in or something. Doubt it, but I suppose anything is possible, especially if someone has golden ears.
The only Pro/Premium difference in sound I can think of seeing mentioned is due to the clamping force, with more clamp = more bass. I extend the headband of my Pro farther out so it doesn't clamp as hard, and amount of bass has nothing to do with it. So I think sound difference between Pro and Premium of the same ohms shouldn't be a concern. Could also just bend the headband for more or less clamp. note: not recommended and may void warranty.
I guess the Pro only comes in 250 ohm.
250 needs a decent amp. 600 ohm needs a bigger amp. A review around here says the 32 actually needs more amp than the 250 does. I've seen other people say 32 is easier to drive. I would assume the 32 is easier to drive, but I don't know. I only have the 250 Pro.
![biggrin.gif](http://files.head-fi.org/images/smilies/biggrin.gif)
