Originally Posted by josimcy
I don't need isolation, necessarily. E3s aren't great with the detail? When you say thin for the ER-4's, is it enough to detract from the richness of the sound?
Did someone say no isolation? Did you say you need richness and detail?
Stax SR-001 Mk II.
I've been preaching about these for a while, and people just don't buy it. That's ok, I'll keep preaching. People don't know what they're missing. This is the best sounding canalphone outside of custom-molded IEM's by a considerable margin.
I guess one factor that has detracted from it's success was the lack of isolation and general lack of practicality, as you need to carry around the amp. But if isolation isn't an issue, then I simply don't see any other alternative. The only reason why I would ever prefer ER-4's or E5c's is for their isolation, which admittedly comes in quite handy at times. This, though, is definitely my cup of tea.
So, you're lazy and you don't want to use "search." How does the 001 sound?
It definitely has a shure-ish sound, well on the warm side of tonal balance, with a nice, rich and punchy bass but not even slightly bloated, absolutely breathtaking mids - better than my SR-404, more liquid and transparent, though not quite as resolving, and a very articulate, but also fairly rolled-off treble. Sounds similar to the E5c? It is, sort of. It is far more detailed than the E5c though, and it also has a far better soundstage, with excellent instrument separation and precise imaging. Obviously, it won't do soundstage quite as well as a full-sized can, or rather it
shouldn't, but somehow I find that only the SR-404 will beat these in soundstaging (out of the equipment that I am very familiar with). They compress the acoustic space, which is understandable, but portray the relative depth and instrument placement very precisely.
Sound problems? Well, the treble is a bit rolled off, and the bass is slightly lacking in texture. That's it.
get them here:
http://www.audiocubes.com/category/E...II_System.html
the Audio-Technica CM7 is a great earbud, and it's well worth the price, both for the style and the sound. The Stax, though, is in a different class. It should be just outside your budget - $239, with an additional $80 in accessories which you may want to buy later (power supply and step-down transformer). You'll also need a good cable between the amp and your player, since this is a very hi-fi canalphone, and will not tolerate poor equipment. But, you don't need to shell out for all of this at once. Once the system is assembled, you'll have one of the best soundging portables period.
You've been recommended to
