johnjen
From the manual…
"IMPORTANT
We recommend leaving Yggdrasil on continuously for best performance.
Seriously. No kidding.
Yes, we know, this sounds like hoo-ha about “burn-in” and magick discs/stones/markers/etc. But in Yggy’s case, this is a real thing, and a serious recommendation.
Why? Because the mil-spec D/A converters in Yggy really do operate best once they’re up to temperature. As with a lot of other components inside the box. So the logical solution (at a power cost of $50-100 per year, depending where you live) is simply to turn it on, and leave it on. This is facilitated by inconveniently placing the power switch in the rear.
snip
Sooooo… turn it on, leave it on, and see if you can't hear a difference after it’s been on for a few days.
And yes, this applies to first turn-on, too."
And from personal experience, after 'going cold' and then being turned on again, it will take between 24-48hrs of continual operation to return to optimal operation.
And that is AFTER the initial settling in when new, which can take several weeks of continuous operation.
And it isn't just a matter of reaching full temperature, even though that is the common perception.
Welcome to the world of tweako audio where the audio-phool is expected to live with a certain amount of inconvenience in order to reach those long sough after sonic heights of nirvana.
JJ
"IMPORTANT
snip
JJ
