earnmyturns
I have found the Singxer F-1 DDC to be a great addition to my computer to Yggdrasil chain. The output from the Singxer F-1 is SPDIF coax, but that seems to work much better than USB. The Singxer seems to deal with the USB crap better than Yggdrasil and feeds a clean well clocked SPDIF signal to Yggdrasil. To isolate the computer systems side of the chain from the audio systems side of the chain even more, I will be inserting a UpTone Audio ISO Regen (using an UpTone Audio LPS-1 power supply) between the computer and Singxer F-1. I will plug the ISO Regen into the Singxer using an UpTone Audio USPCB connector. This is a USB to USB printed circuit board that passes a near perfect USB signal through unlike a USB cable. This setup will provide the Singxer F-1 with a near perfect USB signal and very clean DC power.
I may try a DDC that has an AES/EBU output someday. I want to see what The Schiit Audio Eitr is before I make any more decisions.
I'm leaning towards the theory that getting AES to the Yggy is what matters most, not what you do upstream of a good AES source. With AES into the Yggy, the USB receiver within the DAC and its noise are out of the picture. There may be better AES DDCs than the SU-1, but I would go light on USB mumbo-jumbo upstream of the DDC (cables, decrapifiers) since a good DDC does what matters, put out a well-clocked, balanced S/PDIF signal on the AES/EBU cable.
