snip
Why don't you explain why it takes hundreds of hours to burn in the Yggdrasil yet playing music through it makes no difference during that process.
I posted my grasp of just this subject in the Cookbook thread.
http://www.head-fi.org/t/781268/the-diyrs-cookbook/300#post_12384903
But also let me add this additional thought.
Every component in a new piece of gear has very few hrs of operational time,
in the circuit it now
finds itself.
True they were tested by the manufacturer for functional and operational conformity and to hopefully weed out the early infant mortality casualties.
And none of this initial testing by the manufacturer is going to be even close to the operating conditions those individual parts will be operating under, while in the final product we wind up with.
And true enough after assembly most gear is burned in at the factory for xxxhrs. to help weed out yet more of those early infant failures.
Still the observed behavior that has been repeatedly reported is that the Jggy needs about a week of continually being 'ON' before the real magic happens, and I posit that attaining the full benefit of burn in (or whatever terms you wish to use) takes longer.
IOW all of the active, and passive components are getting acclimated to the electrical 'environment' they will be operating within.
This includes the range of, and the dynamic interaction between, the voltages, current, frequencies, temperatures, magnetic fields, etc. they will now be operating within.
And none of these components are 'fixed' with relation to each other in how they respond to changes to all of these parameters, and my supposition is that they 'settle into' a more fixed pattern of response(s) to these variable parameters, as they gain operational hrs.
Which implies that a signal being passed thru the device is a necessary aspect of all this, which in turn means it isn't just the number of hrs the device is 'on' but how long has it been operating, and not just idling.
Just a few thoughts to ponder.
JJ
