Are there any sq-related disadvantages in using the RCA unbalanced outputs on the Yggy as opposed to the balanced outputs? I have the yggy feeding my pre-pro via the XLR outputs in order to service my speakers, but I also have it feeding my Violectric 281 via the RCA unbalanced cables, and i am wondering whether I am shortchanging the Violectric/Headphone connection in any way, sq-wise... I use the 4-pin balanced out connections on the V281 almost exclusively for headphone listening, so it would be somewhat less than ideal if the sound is at the input point was less than optimal.
The second question is whether there is a good way of splitting the signals from the Yggy's Balanced XLR outs so that they can alternatively be used with either the pre-pro for speakers, or the Violectric V281 for Headphones...
If this second option (of using an XLR splitting connector) is viable, could anyone suggest an appropriate splitter cable? I have attempted using the type pictured below in a slightly different application, with different components, and it did not work out too well (of course, it is always possible that I may not have used it correctly)...
Any helpful suggestions would be welcome :
