Schiit Valhalla 3 - Impressions Thread
May 15, 2025 at 10:15 AM Post #646 of 829
I haven't contacted Schiit yet, however, I have been facing the same issue since day 1 with a set of perfectly matched pair 6N1P tubes. Relative to the tubes that came with the Valhalla 3, my matched pair tubes produce a much more enjoyable sound to listen to. However, the amp enters protection mode pretty frequently after 15-30 minutes of use...
There was another person who commented on this issue in this thread (post #539), and they found that connecting the amp directly to an outlet resolved the problem for them. They had it connected to a surge protector previously, which was the culprit to the protection mode issue that we are all facing. And mine is also connected to a surge protector and cannot reach an open outlet.... But today I will be receiving a 10ft power cord with the same specs as the default power cord that will be able to reach a separate outlet. So, I will update this comment or will post a new comment if this resolves the issue for me as well.
Ultimately, I really hope this does resolve the issue....as I had zero issues with compatible tube rolling on my Valhalla 2 connected to the same surge protector. Additionally, I have sets of matched pair JJ ECC88-Gs and Gold Lion 6922s coming in the mail within the next month! And I really hope that I can compare them and enjoy them without any issues.
When in doubt, contact Schiit Audio support. Better to try to resolve it with their help than worrying about it. 😉
May 15, 2025 at 11:49 AM Post #649 of 829
Edit - Also, it always takes exactly 60 seconds for my amp to start playing audio after being turned on, regardless of which tubes are installed... But Schiit-Talker says that audio output should start within 15-20 seconds after powering on the Valhalla 3....so perhaps there is an issue with my unit...or perhaps the surge protector is causing this delay as well. I should hopefully have the time to find out if this is the case tonight and will keep you guys updated.
Interesting, my startup time is about 40-50 seconds, didn’t realize that might indicate a problem.
May 15, 2025 at 12:59 PM Post #650 of 829
My startup time is also 40-50 seconds. Using the tubes that came with the unit, and I previously had it plugged into a surge protector, but I just tried plugging it directly into the outlet, and the startup time didn't change. I'll let you all know if plugging it directly into the outlet has any effect on protection mode... which I actually didn't experience at all last night during a long session of both headphone and preamp listening. I'm feeling like the protection mode was happening when I was frequently changing gain settings and sometimes using too much power/volume, which I think it's doing what it's supposed to.
May 15, 2025 at 1:14 PM Post #652 of 829
Well the tubes arrived early. :L3000:
What is your take on these tube adapters? I have the Feliks Echo Mk2 which uses the same tube types as the Valhalla 3. But apparently it's a bad idea to use 6SN7 tubes in the amp with adapters. Any issues with the Valhalla 3?
May 15, 2025 at 1:19 PM Post #653 of 829
No issues running them with adapters in the Valhalla 3 thus far. I actually had a conversation with someone regarding them on another forum, and they thought the 2.7A of total heater current was sufficient. YMMV, and all, but like I said no issues as of yet. The only warning was if I rolled the power tubes to something with a higher current draw than stock it would cause issues. *at the same time...
Edit:
I also tried one of them on my Vali 3.
May 15, 2025 at 1:36 PM Post #654 of 829
Edit:
Hmm okay. Maybe the Feliks Echo Mk2 just can't handle the 6SN7 tubes. Each amp is designed differently.
May 15, 2025 at 1:38 PM Post #655 of 829
6SN7 and 6CG7 have 2x the heater current needed compared to 12AU7 or 6922
May 15, 2025 at 1:40 PM Post #657 of 829
So basically it's not a good idea to use them in amps like the Valhalla 3 and Echo Mk2?
May 15, 2025 at 1:55 PM Post #660 of 829
Depending on the allowable heater current. With V3, I believe it's sufficient for a pair of 6SN7s. Not sure about the Echo
but it's feasible to use 6922 tubes in 6sn7 amps with adapters with expectation of low gain ?
Yes. The rectifier is not saturated yet so you're more than welcome to use 6922 in place of 6SN7
