I stream files from my NAS. The chain is NAS -> switch -> router ->wi-fi to the laptop. The power supply upgrades in the network absolutely do improve the final sound. In fact this chain sounds better than the same files stored in the hard drive of my laptop.
The HTS-2000 is not a typical Monster product. It was designed by Richard Marsh, a respected audio expert, under contract for Monster. It improves the sound of any line level equipment I've used it with, but is not suitable for power amps.
Furman is the leading designer of power conditioning for the pro market. The PST-8 incorporates sophisticated technology for line level components and definitely cleans up the sound. Unless you've tried it, I agree, it's just your opinion.
https://furmanpower.com/product/15a-8-outlet-surge-suppressor-strip-w-smp-lift-and-evs/
I tested the iPower2, which is an update of the base model iPower. The iPower X does sound better than an iPower. It's possible it provides some improvement., but I doubt it for two reasons:
1. Power is routed through the Modius' internal switcher.
2. I could hear no difference in these two scenarios:
- Modius SMPS vs. iPower connected to the Modius
- iPower connected to an iDefender for USB power, no power supply connected directly to the DAC. In this case, I was able to instantly A-B by disconnected the iPower cable from the iDefender. The sound did not change. So either the iPower and Modius wall wart sound exactly the same (unlikely), or Schiit is right, and a PSU upgrade is not worthwhile.
I compared the Modius connected via USB to my laptop vs. coax from my Eitr. The coax was awful, no contest. I was able to improve the Eitr a lot with a bunch of tweaks (iDefender, iPower, USB Isolator, iPurifier2).
USB is superior technology to coax, because S/PDIF has the clock signal embedded. With SPDIF, there are always two clocks, source and DAC, which can never synchronize perfectly. With their Unison USB design, Schiit finally got it right. The designer has now revised his opinion and admits that USB is superior to SPDIF. There's an explanation from Barrows of Sonore here, on why USB is best:
https://audiophilestyle.com/forums/...f-converters-shootout/page/23/#comment-489519
