Runrunsmithfly
Previously known as ssmith3046
I really like the Modius ( AK4490 ) using the balanced output.
Hi NiftyVT, if you dont mind me asking, which Modius are you using and what TV is it hooked up to? I was guessing Modius E but didn't want to assume.
I would imagine you would do some damage to your equipment that way. XLR is 4v as you point out but se is only 2v. My advice would be to go to the Schitt website and purchase the Schitt Sys which would take your se output and split it into two seperate se outputs controllable with the flick of a button with a volume control to boot. Better safe than sorry and it is only $49!I have been researching this question and been a little confused about the exact answer. If I connect the balanced outputs off the modius to a SE amp using a xlr to RCA cable, would I cause damage to either the DAC or Amp? My understanding is the amp would start clipping before max volume due to the 4v input, but besides that it should be ok?
I'd like to run two SE amps off the Modius at the same time if possib
An RCA Y-splitter or Y-cable would work fine for this, for example (there are lots of alternatives in all kinds of price ranges):I have been researching this question and been a little confused about the exact answer. If I connect the balanced outputs off the modius to a SE amp using a xlr to RCA cable, would I cause damage to either the DAC or Amp? My understanding is the amp would start clipping before max volume due to the 4v input, but besides that it should be ok?
I'd like to run two SE amps off the Modius at the same time if possible.
I’ve used this configuration with XLR to RCA cables and haven’t noticed any ill effects, although I am running it balanced currently.I have been researching this question and been a little confused about the exact answer. If I connect the balanced outputs off the modius to a SE amp using a xlr to RCA cable, would I cause damage to either the DAC or Amp? My understanding is the amp would start clipping before max volume due to the 4v input, but besides that it should be ok?
Not familiar with the specific reason why but recall hearing Goldensound say cables that convert balanced to single ended are not safe.I’ve used this configuration with XLR to RCA cables and haven’t noticed any ill effects, although I am running it balanced currently.
I don't think he meant burn your house down unsafe, but more like damage downstream equipment unsafe.Not familiar with the specific reason why but recall hearing Goldensound say cables that convert balanced to single ended are not safe.
It's not even that dangerous. I've used XLR to RCA adapters in a few situations and use them currently to feed the subs in my main system. The worst thing that can happen is that you get a hum, because some gear doesn't like having the unused pin grounded. Benchmark makes a cable that floats the third pin instead of grounding it, which eliminates the potential for hum:I don't think he meant burn your house down unsafe, but more like damage downstream equipment unsafe.
No way! XLR to RCA adapters are available from numerous respected manufacturers and common in pro and consumer audio systems.Not familiar with the specific reason why but recall hearing Goldensound say cables that convert balanced to single ended are not safe.
