About two weeks ago I got my shipment from Schiit for a new Asgard 3 and Modius stack. I am using a Sony MDR-Z7M2 56 ohm headphones with this Schiit stack. I am using my PC (with Asus mother board) as a source. There is a lot of other gear I had when modding and tweaking my main HT system that I am using with this setup like power conditioners, cables, etc. But the purpose of this post is to share what I did to address the USB noise that is in my or a PC. I have read others are also experiencing PC USB noise issues.
Usual listening levels for me is between 10 o'clock and 12 o'clock (peak volume) in high gain. First if no USB cable is attached to the PC the Modius the amp is dead silent at max volume, so I know it is not the amp or Modius. If the supplied USB cable is used for power and signal from PC (using the USB port with the least noise) at 12 o'clock the noise starts and gets louder as the volume knob is turned. Yes, some USB ports are quieter then others. This noise sound like a ground loop or static. So I tried a Toslink from PC with the supplied USB cable used for power using the supplied walwart and that is much quieter, no noise until 4 o'clock which is almost max volume. By the way I found out most PC motherboards either have digital out with card supplied or a separate board can be purchased (what I did) to plug into the motherboard. This board costed me $13.99 on Amazon. Here is the link:
https://www.amazon.com/gp/product/B01LWNKIKN/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
But I found the sound via Toslink to be different and wanted to experiment with USB more. So a trip to Frys Electronics and I picked up a $3.99 cable. Used this cable to the supplied walwart and used the included cable to PC USB. Now I can switch back and forth to see which I prefer, USB or Toslink. But the noise on he USB is still there when volume knob gets to 12 o'clock. So then I used a small thin strip of electrical tape and covered the power connection inside the USB A plug that goes into the computer. It worked, seems the walwart will power the USB signal outside without using PC USB power. Sonics are the same and no noise until 2 o'clock. So then I taped off the ground also in the USB plug and again it worked and the noise now does not present itself until about 3 o'clock.
So what I have learned from this exercise is the power and ground is (or can be) very dirty or noisy. Definitely the case in my PC. Noise at any level will effect sonic performance, this is why I want to get rid of the noise. By lifting the ground and power from the signal carrying cable the noise is eliminated within the volume range I listen to. Different USB ports in the same PC can be quieter then the others. The supplied cable when plugged into the supplied walwart sound a little better then the $3.99 cable from Frys (USB cable quality can matter). I will buy and try a few other cables and see if there is a difference for USB signal and power. The Toslink cable I used is a glass cable purchased from Amazon. Usually glass Toslink sounds the best in my experience.
Hopefully this helps someone!
