Sonic Defender
For sure, it is supposed to be a very nice little device.L30 is out now and pretty good tooo if you don't need 4.4mm Bal out...
For what it is worth, I don't own and have never owned a Topping device. I have purchased several Schiit pieces of gear though so I rather doubt anybody could support the notion that I'm advertising for Topping.
What? Jot's amp is far better than Topping A90, it isn't lacking anything. Also dac module (both ak4490 and multibit) uses usb gen 2 which is really old. DAC module (both ak4490 and multibit) in Jot can't outperform Modius. I'm using Modius and Jot with ak4490 dac module and I can say that the dac card is clearly not a competitor to Modius.I had both briefly and it was a very subtle difference. The Modius I think had better definition but the multibit card sounded richer and warmer. To hear an improvement you really ought to get a magnius , aaa 789 or topping a90. The Jotunheim amp section is really lacking imo.
Right. But you may need a plug adapter.Guys, quick questions. The Modius doesn't care for 110/220v difference right?
So yeah, maybe hold off on further emphatic recommendations of gear that serves a different purpose.I haven't really looked at the new Magnius so that will be something for me to investigate.
Why? First off, this isn't a Magnius thread, please note that and it doesn't serve a different purpose, the Magnius is an amp same as the A50s. So what different purpose does it serve? This is head-fi, the most subjectively experienced driven headphone community on the Internet. If you don't like emphatic recommendations you might not want to follow too many threads here.So yeah, maybe hold off on further emphatic recommendations of gear that serves a different purpose.
Modius is better DAC, it has a new usb input - Unison which is head and shoulders above usb gen 2 in dac module ak4490. You can see that dac modules in Jot is really small, they smaller than Modi 3. They just for convenience, for people who want all in one device. Both ak4490 and multibit cards are compromises. Even Modi 3 is better DAC than any of dac modules in Jot.
hmmm. it might be worth getting a modius to use with my multibit jot then. i really want bifrost 2 but its kinda expensive shipped to canada lol
My advice: save up to the Bifrost 2. It is well worth the wait and extra buck. No point in acquiring a different product just to sit there, wondering what could have been.
To each their own then. To me the Jotunheim sounded congested and harsh compared to the the thx 789 and A90. I did use it with both the add on multibit dac and Modius dac. As soon as i switched over to the other two amps I felt the music opened up and lost the harshness that I heard with the Arya and Elegia. I’ve since bought the bifrost and that’s obviously another level from the Modius both in sq and price.What? Jot's amp is far better than Topping A90, it isn't lacking anything. Also dac module (both ak4490 and multibit) uses usb gen 2 which is really old. DAC module (both ak4490 and multibit) in Jot can't outperform Modius. I'm using Modius and Jot with ak4490 dac module and I can say that the dac card is clearly not a competitor to Modius.
Modius is better DAC, it has a new usb input - Unison which is head and shoulders above usb gen 2 in dac module ak4490. You can see that dac modules in Jot are really small, they smaller than Modi 3. They just for convenience, for people who want all in one device. Both ak4490 and multibit cards are compromises. Even Modi 3 is better DAC than any of dac modules in Jot.
The Modius measures better than the Bifrost.To each their own then. To me the Jotunheim sounded congested and harsh compared to the the thx 789 and A90. I did use it with both the add on multibit dac and Modius dac. As soon as i switched over to the other two amps I felt the music opened up and lost the harshness that I heard with the Arya and Elegia. I’ve since bought the bifrost and that’s obviously another level from the Modius both in sq and price.
