Zer0.p0int.Zer0
Yep, you’re right. And I’m happy to be wrong and get educated while increasing my audio enjoyment. So no issues jumping headfirst into this, aside from the confusion. Cheers.
My suggestion if you only have the funds for modius, a modi / magni stack may be a better option at the same price. Or as suggested above, for a bit more you could go for an Asgard 3 with built in DAC. If you get the Asgard, you could always add modius later, fits same form factor.
Good luck!
Edit: obviously there are plenty of non-Schiit options as well, but this being a modius thread and all...
