ckhirnigs113
- May 19, 2005
I have the same setup (Yggy A2/MJ3) and really liked the synergy with the Caldera while I had a loaner set for a week. I used the same settings on the MJ3 that I use with my Meze Elite (XLR in/out, high gain, push-pull, no feedback). I've gone back and forth between using low gain and high gain. I am starting to doubt if I can tell the difference.First impressions of Caldera + MJ3 + A2 are quite good. Maybe bassier A2 is not the perfect fit but works well enough. Pixies' Bossanova sounds intoxicating. Push-pull appears necessary. Skipping feedback. Despite ASR, I think the tuning makes a lot of sense.
I do switch from Push-Pull to Single-Ended Class A when using my ZMF Auteur, though it sounds great in Push-Pull as well.
