Melting735
My only complaint is the power switch locating at the back. It would be a slight pain for people like me who needs to reach the back of the shelf/rack. FV is the same :s
Maybe better. Chokes! Def could be quieter, with headphones near silent in SE mode. Depends on high the output is and if a person wanted long runs to their amps aka balanced cables. And of course more inputs, but if you have URD ....Has anyone tried using mjolnir 3 as a pre amp yet? How do you think it would compare to other pre amps like the kara?
There's maybe one hour a day where the sunlight reaches my desk. I give you the Mjolnir 3!
You should be good. It vaguely mentions it by way of, "Note 2: There may be a small to moderate glitch when switching gain or mode. If you would like to avoid this, unplug your headphones. We do not recommend IEMs with this amp in any case.".It doesn't say in the manual whether one should turn the amp off before changing any of the sittings.
Should I turn the amp off before changing any of the settings?
For sure. It's a Pinza in the size large. It's great with all but the gnarliest of cables.Hey, can you share where you get the fancy weight for cable management?
Looks like a very neat solution for listening at the desk
At least, turn the volume down if you're listening at ear-bleeding levels. I tried it at lower (sane) volumes and had no ill effects to either my ears or my HPs.It doesn't say in the manual whether one should turn the amp off before changing any of the sittings.
What amp(s) were you using before?After more time behind the mjolnir 3 it is becoming my favorite amp. The sound is quite decadent and beautiful. It maintains treble detail, and provides punch to bass even on susvara and ab 1266. I am hearing so much detail from the susvara and 1266 it really is incredible.
I've used magni, hdva600, mjolnir 2, dna starlett, dna stratus, bliss kte.What amp(s) were you using before?
Are you liking the MJ3 more than the other amps, including the Bliss, with your planars? I have a Meze Elite that is my main headphone, and it's relatively easy to drive. It will supposedly scale with better amps, so I'm tempted to try the MJ3. I use and like the Cayin iHA-6 currently. I have recently upgraded to a Yggy A2 from an OG Bifrost 2, and I wonder if my amp is the weak link in the chain now. Don't get me wrong, it sounds excellent, but as always, I'm curious if it could be improved.I've used magni, hdva600, mjolnir 2, dna starlett, dna stratus, bliss kte.
Headphones: hd6xx, hd800s, lcd-x, Susvara, Abyss AB 1266 Phi tc.
Dac: modi 2, yggdrasil og a2.
