Smoothstereo
Anyone able to compare the MJ3 to Headamp GSX Mini ?
You're looking at the wrong statistic; low-sensitivity planars want more current over raw wattage. MJ3 has a power supply more akin to that from a speaker amp than one for headphones; current is not a problem. Few planars are harder to drive than the HE-6 and MJ3 drives those quite well so long as you're in high gain and aren't listening over 100dB, even in SE Class A. Susvara and Abyss are comparably difficult to drive and should also work. There have only been a couple of occasions that the HE-6 has distorted over the past several days as I've been listening, and switching over to Push-Pull cleared that right up at only a slight cost in overall fidelity.I came away thinking I want to own this amp but can't justify the purchase ... most of the headphones I plan to own in the future are power-hungry planars so I am a little worried that "only" two watts is not enough. I understand that there is a lot more to good sound than a high wattage rating but when you are blind-buying headphones costing several thousand dollars, you want to make sure you have an amp that is powerful enough. I think that's going to be a stumbling point for a lot of buyers who are unsure whether the MJ3 is a match for their expensive planar headphones that (allegedly) require small nuclear reactors to drive. But, ultimately I am really glad this product exists and Schiit took the time to make it, knowing that it would never be a big seller. It definitely opened my eyes to what is possible with solid-state designs and different topologies.
Damn, I never even got a shipping notice! Just in production. Ordered Sunday, arrived Friday. Pretty neat!Wow, Schiit shipped my MJ3 in 30mins right after I placed the order
Agree, you can max out hard to drive 13 to 23 ohm DCA planars in lo gain, I would rather save my ears ... in high gain you're set to go deaf.You're looking at the wrong statistic; low-sensitivity planars want more current over raw wattage. MJ3 has a power supply more akin to that from a speaker amp than one for headphones; current is not a problem. Few planars are harder to drive than the HE-6 and MJ3 drives those quite well so long as you're in high gain and aren't listening over 100dB, even in SE Class A. Susvara and Abyss are comparably difficult to drive and should also work. There have only been a couple of occasions that the HE-6 has distorted over the past several days as I've been listening, and switching over to Push-Pull cleared that right up at only a slight cost in overall fidelity.
You're looking at the wrong statistic; low-sensitivity planars want more current over raw wattage. MJ3 has a power supply more akin to that from a speaker amp than one for headphones; current is not a problem. Few planars are harder to drive than the HE-6 and MJ3 drives those quite well so long as you're in high gain and aren't listening over 100dB, even in SE Class A. Susvara and Abyss are comparably difficult to drive and should also work. . . .
Lol, did you paint your knob?And Schiit should offer it with a black knob![]()
No lol, just an easy swap. Had an extra one laying around from eBay.Lol, did you paint your knob?
According to the manual it says when feedback is on it’s a lower impedance. Couldn’t tell you the difference. I can hear a difference and depending on the headphones it’s better or worse. I like it on with the D8KP LE. Sounds cleaner to me.I thought it was confirmed by JS that output impedance is the same no matter what about 0.25 ohm
I think the only difference is 0.13 on SE and 0.25 XLR maybe the manual is wrong, I was actually hoping it would be switchable to about 25 ohms but it was confirmed in this thread or the other one by JS that feedback doesn't change output impedance.
Are you asking for a table for when to use them (best setting for a headphone) or something else?I know @Jason Stoddard said there are a lot of options/toggles on this amp. Is there any one place where they are all shown?
For the nerdy amongst you, something like a truth table:
feedback on, feedback off
push-pull, single-ended
balanced, unbalanced
