TK16
These D-getter Hamburg 6201 are freaking incredible sounding despite the under minimum 2,500 gm. Probably doesn't have much life left in them but as often as I roll should be ok.
Give them a deadline to respond and then a dispute. Went from getting a reply in 3 days til a full week. Definitely not buying from them again.Never got my first batch. Still waiting on the second batch. I'm emailing them tomorrow for a refund or dispute with PayPal. Won't be shopping there anymore.
This info it is from MJ2 manualAnyone know the MJ2 power output at 200 ohms?
Thanks.This info it is from MJ2 manual
Maximum Power, 32 ohms: 8.0W RMS per channel
Maximum Power, 50 ohms: 5.0W RMS per channel
Maximum Power, 300 ohms: 850mW RMS per channel
Maximum Power, 600 ohms: 425mW RMS per channel
I am guess round 1.0W.
~ Yes, if you can find a Mjolnir II. If not, I recommend the Schiit Valhalla II output transformer-less hpa. ($349+taxes etc). It is a tube hpa that is not full-blown “tubey”. It has some of the ‘snap’ of solid-state.I have a pretty decent solid state amp and wanted to get a tube amp that has enough of the Tubey sound signature without being a full tube amp, could I reasonably achieve that with mjolnir 2 through tube rolling?
Thanks for the detailed feedback. I do have an option on a mjolnir II, would you pick a mjolnir II over a Valhalla II?~ Yes, if you can find a Mjolnir II. If not, I recommend the Schiit Valhalla II output transformer-less hpa. ($349+taxes etc). It is a tube hpa that is not full-blown “tubey”. It has some of the ‘snap’ of solid-state.
~ You can roll the front tubes (6DJ8/6922 type, experiment with others+adapters). The back tubes are 6N6Ps. To upgrade, go with Foton or NEVZ.
~ The Valhalla II can drive various low impedance hps besides high impedance hps. I use the Valhalla II with Audeze LCD-X (20 ohms) and Gjallarhorn JM Edition (33 ohms). Wonderful!
I have no personal experience with Valhalla 2, but I can confirm that MJ2 is fantastic with low/high impedance and planar/dynamic HPs.Thanks for the detailed feedback. I do have an option on a mjolnir II, would you pick a mjolnir II over a Valhalla II?
Me personally would definitely choose the MJ2 over the Valhalla. Unless you're running high impedance headphones then I recommend the Valhalla.Thanks for the detailed feedback. I do have an option on a mjolnir II, would you pick a mjolnir II over a Valhalla II?
