Schiit Midgard - Impressions Thread
- Thread starter XERO1
Saaki
Thank you for the detailed answer! That really helps.
DJ LP
- Mar 15, 2011
Hello. I need a little bit of help. I have the HiFiMan HE1000v2 headphones and I'm looking at one of your amplifiers for them. I'm looking at the Asgard, Jotunheim, Midgard and the Lyr. I want a wide soundstage, with plenty of detail and with a creamy organic sound to it. Am I asking too much? If not, which of the amps above would work best for me? Thank you in advance for your help.Inaccurate and mischaracterization. The full story is up in each chapter--Magnius and Midgard both.
Magnius--we tried two designs, both op-amp based. I liked one. Staff liked another. I was outvoted. There was never any intention of not releasing it. The only question was which form.
The Midgard--yes, I forgot we did Magnius. This can be a good thing: it's a reliable, trouble-free product. And it did help break the back of the "schiit can't make measurements" thing that was going around at the time.
But yes, I will lean towards discrete. A more linear stage without the need for tons of feedback to get good measurements, based on our own tech that can be improved, rather than me-too waiting for the latest new op-amp from TI or AD...that always wins for me. But that's me. And that's leaving aside the opportunity to introduce Halo.
If you're in the area, come to my Measurements presentation at the Dallas CanJam. It's very illuminating in all contexts...from us being measurements-driven (starting 30 years ago, before Schiit even existed) to the problems inherent in the "one number to rule them," to what we can do about it to get some balance. I'll put the PDF up here on my thread, I'm sure, afterwards as well.
Saaki
How much ventilation does the Modius/Midgard stack needed? I keep seeing those under desk mounts and it got me thinking I could 3D print one for myself to save desk space. However I'm concerned about having enough room around the units so they don't overheat.
adydula
- Dec 14, 2010
I run them right on top each other with Midgard on top. Modius has no vents. Midgard runs warm but no real heat issue to worry about...How much ventilation does the Modius/Midgard stack needed? I keep seeing those under desk mounts and it got me thinking I could 3D print one for myself to save desk space. However I'm concerned about having enough room around the units so they don't overheat.
Saaki
Great, I'll look into 3D printing a mounting bracket in that case.
adydula
- Dec 14, 2010
The Midgard has top vent holes so leave some space on top to allow for the the heat to dissipate. I would think an inch or so...
Saaki
That's exactly what I was thinking — have a space on the top so it can breath.
Saaki
My Midgard arrived today but I'm waiting for my Modius to get here tomorrow. Would it be a bad idea to hook up my SMSL iDEA to use as a DAC the meantime? I know it has a small amp in it so I'm not sure how that works hooking up an amp to an amp or if I can cause any damage.
This is the SMSL product in question: https://archimago.blogspot.com/2017/05/measurements-smsl-idea-usb-dac.html?m=1
adydula
- Dec 14, 2010
Wait...My Midgard arrived today but I'm waiting for my Modius to get here tomorrow. Would it be a bad idea to hook up my SMSL iDEA to use as a DAC the meantime? I know it has a small amp in it so I'm not sure how that works hooking up an amp to an amp or if I can cause any damage.
I say give it a try! It can't hurt anything. Just be sure to turn it all the way up.
And it should give you a small...'iDEA'... of what the Midgard sounds like.
![dr-evil-evil-laugh.gif dr-evil-evil-laugh.gif](https://cdn.head-fi.org/a/12209607.gif)
Hifiearspeakers
Absolutely fire it up!My Midgard arrived today but I'm waiting for my Modius to get here tomorrow. Would it be a bad idea to hook up my SMSL iDEA to use as a DAC the meantime? I know it has a small amp in it so I'm not sure how that works hooking up an amp to an amp or if I can cause any damage.
Saaki
Is there anything I need to know about setting the volume on the SMSL? I'm very curious how the SMSL iDEA will sound versus the Modius. It has an ES9018Q2C in it.
Not really. Just turn up the volume on the iDEA until it maxes out. Virtually all dongle DACs output less than 2V from their 3.5mm jacks when maxed out, so there is no chance of clipping the RCA input of the Midgard.
Then turn on the Midgard and turn up the volume!
FYI, you might need to use the High Gain setting if you are using your HD 6XX because of their high 300 ohm impedance.
FYI #2, make sure to always turn down the volume before switching from Low to High gain, if music is playing while you are doing this.
Total: 6 (members: 0, guests: 6)
