yeah, I'm sorry about that.I am in this camp also. Everyone's always trying to make something a showdown, it's OK to do it all or anywhere in between.
*comes to a fiddlesome, analogue EQ owner&impression thread, then craps. Haha.
You still don't own the Loki Max, but at least your replies are sensible and you seem to like hanging on in the thread. You said you've tried a lot of other analogue EQs, which ones would you recommend? Or with digital ones would you recommend that might be easier or more "on the fly" like the Loki Max? I haven't pulled the trigger yet, so I'm happy to take advantage of your experience and maybe catch a different perspective on this one.
Schiit Loki Max Impressions
- Thread starter Ableza
all schiit eq's increase volume output . its not just you. found this multiple times.Schiit returned the Loki Max to me within two weeks, with a note saying it tested fine and there’s no channel imbalance that they could detect.
Is it just my unit, or when the Loki Max is turned on and the EQ circuit is switched on (even with all knobs set at default), does the volume sound louder? That is, as opposed to when the Loki Max is turned on and the EQ circuit is switched off? Is it adding gain when the EQ circuit is engaged, regardless of where the knobs are set?
Orange5o
Anyone with the Max have a lokius prior to? Wondering if it behaves the same other than remote control and extra bands, or if there is any added accuracy or transparency, etc
Thank you
Thank you
Ableza
re: level changes. Interesting that some report this. With my Max, if I leave all controls set to zero I can toggle the bypass switch and hear no level changes.
dcguy73
Formerly known as dc_guy
Maybe this is a dumb question, but are you using the RCA output or the XLR output? I only hear the gain difference at the default settings with XLR output.re: level changes. Interesting that some report this. With my Max, if I leave all controls set to zero I can toggle the bypass switch and hear no level changes.
Ableza
XLRMaybe this is a dumb question, but are you using the RCA output or the XLR output? I only hear the gain difference at the default settings with XLR output.
belgiangenius
- Sep 10, 2016
Thank you
I have both. I'd say operation is largely the same. They both have 6 bands.
I'd say the Loki Max sounds better, but then I want to believe that having paid 5X as much for it.
it's shocking to me the lack of comparisons online between the two of them.I have both. I'd say operation is largely the same. They both have 6 bands.
I'd say the Loki Max sounds better, but then I want to believe that having paid 5X as much for it.![]()
Ableza
So perhaps you could remedy that situation?it's shocking to me the lack of comparisons online between the two of them.
tbrobison
I think the reason is that it is such a niche product, that there just isn't that much interest in it in the general audiophile audience. I had a Lokius on order for a while, and then cancelled after I found the graphic equalizer's in both Apple Music, and Airfoil do the job for me. Each has 10 bands/frequencies to tweak to one's taste. I only use it on recordings that lack dynamic range. Other times, I don't need to use them at all due to great recording/mastering.it's shocking to me the lack of comparisons online between the two of them.
sure , send me one of each unit pleaseSo perhaps you could remedy that situation?
Anyone communicate with Schiit regularly? I wonder if there's any plans to come out with a Loki Ultimate or something with an 8 band EQ
I tried posting on the main Schiit thread, but any useful post gets drowned out by a flood of nonsense about craft beers and other non-audio stuff, lol
Orange5o
I believe Jason called it the completion of the line
Isn't that what they always say until they get a new crazy idea? lol
hello friendI have both. I'd say operation is largely the same. They both have 6 bands.
May i ask better in what ways please
Many thanks
