I use these Pangeas on all my stuff, they work fine, seem to be nicely put together with all the bells, whistles and buzzwords in the specs, reasonably flexible, come in several different lengths (no need to ball up excess in wads or trim and re-terminate yourself), and are very cost effective as these things go. I use the lowest cost versions except the one I use with my PS Audio Dectet which is 2 meters long. I also replaced the wall socket with one from Pangea for $19.95. Thought it was probably not necessary but when I pulled the existing one turned out to be only about 75% of normal, low quality builders grade, LOL. There is a substantial difference in weight alone. Difference in sound, time will tell. Truth is, when the local Naval Air Station closed 10 years ago or so, and I was no longer directly under the NW to SE landing pattern (depending on wind), all my, sometimes, noise issues went with it.
