Bimbleton
- Oct 12, 2013
Very good point. After a lot of trial and error with lots of headphones and a few amps, I’ve realized a few things.Imo, I think you should consider its character and strengths/weaknesses, whether it is in line with your taste and priorities. It does a lot really surprisingly good, but it also imparts its character, which may not be in line with your taste. Also, one interesting thing about taste, just because you don't like its character now, it doesn't mean you won't like it later. It takes a while to understand it, because it is quite different than your usual SS amps. Your brain/ear may need time to adjust. I was quite surprised when I first heard it, and a lot of conflicting opinions for a while until it settled down.
Secondly and more importantly, you should consider whether it synergizes with your DAC and headphones.
I don't think it is a simple better or worse question. This is quite a polarizing amp. Direct comparison with the usual SS amps is trickier.
- Preference is the Harman target, minus ~2db of treble, so a touch warm
- Don’t like mid bass bloat
- Value good bass slam (something the Singxer lacked)
- Appreciate a good volume range (so not too much gain)
- Can tell resolving gear from non-resolving gear
I think the Jot 2 will be a good match for my LCD-X ‘21, except for the volume range. And I’ll aim to pair it with a Bifrost 2.
Just tried an iDsd Signature, and while it is a lovely device — warm, feature-rich, shockingly deep bass — it’s too clunky and too easy to bump the volume knob and deafen myself.
I think I’ll keep the Qudelix as my portable rig, and aim for a Bifrost2/Jot2 combo for desktop listening.
