I received my Freya last weekend, 2 days ahead of the Fedex scheduled delivery date, so I've spent maybe 6-8 hrs with it.
Caveat: I've been a solid state guy all my audiophile life, and I've designed / built some (basic) gear ranging from amps to buffers and amps. My friends consistently remark that my gear / systems are 'tubey', and I have nothing against tubes, except that for diy I prefer playing with the lower voltages in solid state designs.
First impressions of the Freya:
Boy, it's good!! For $699 it's amazing. Some years back I built an 80+ step remote controlled preamp with buffer. I could not come close to the Freya's spec without spending that amount, and the buffer would have to be op-amp based, and the metal work a lot shoddier.
- As a passive volume control the finer steps for volume control are just what I like. Motorised volume controls are much too unpredictable, and 64 steps would be too coarse for my tastes.
- I'll assume passive = neutral. By that accout, the Jfet active buffer sounds very neutral too, although it sounds deeper, fuller and more extended.
- The tube stage (using stock Schiit tubes) sounds very nice. I did not notice the huge gain in soundstage that others have mentioned, although the mids are very nice - smooth, clear. My speakers are essentially flat to 25Hz and have good RAAL ribbon tweeters, and using the tube stage I felt a distinct loss of the deepest bass, and a slight loss of sparkle. Because of this and my listening preferences (mostly classical), I decided to remove the tubes and just use active buffering for now,
- Leaving the unit powered up, I was quite taken aback by the change in sound after ~24hrs. the sound of the Freya smoothened a *lot*. I'm used to some change as a unit runs in, but this was pretty noticeable, and my wife noticed it too. It's become more tube-like! My previous amp was an integrated (Krell Vanguard), which I reckon was quite neutral. Currently the Freya is connected to a small Redgum Mosfet integrated with volume set at max. The Redgum uses a passive volume control and sounded quite close to the Krell - maybe slightly deeper, a little less powerful. With Freya -> Redgum the pair sounds rather different - warmer, larger sounding, even deeper. Source is a Gumby. It seems like this combo benefits from an active buffer feeding the amp, and the Freya adds body & polish to the setup.
I'll be especially interested to hear from users who listen with the Jfet buffer stage, and those who give the Jfet buffer more time to run in. I would not be surprised to hear that initial impressions change quite a bit, given enough time for the unit to burn in.
