I mainly bought Schiit Wyrd to see if it will eliminate a cyclical hum/buzz out of my iMac USB, when iPhone 5S is on same desk.
happens at regular intervals through Concero HD into Vali and right channel of my headphones.
as others of stated, Wyrd doesn't fix this.
Having spent a few days with the Wyrd, here are quick findings you can accept or dismiss at will:
source:
macbook pro 13” retina—>24/96 and DSD files—>Aurdirvana+—> usb chain —> GeekOut450 0.47ohm jack to Heir Audio 4.AiS
Config #1:
GO450 directly in macbook USB port
my base config. on stage presence of music, very balanced and detailed. bass/mid/trebles all clear, precise.
black background (oh teeny tiniest amount of air) with no music playing. even with Audirvana volume at maxed at 0dB.
listening level of -38db is comfortable for testing/detailed listening.
cymbals have a shimmer and sparkle to them, bass guitar lines extend nice and low.
drum skins have a (realistic) hollow echo at certain times.
Config #2:
macbook pro connected to Apple Thunderbird monitor
GO450 plugged into USB at back of monitor
changes detected: nothing obvious. volume levels stayed the same, bass and treble characteristics unchanged.
soundstage, black levels unchanged.
Config #4:
macbook pro USB connected to Wyrd.
GO450 straight into Wyrd.
changes detected:
drums: that “drum skim hollow” and quiet cymbal taps are still present but oh so very tiny slightly recessed.
Wyrd + GeekOut Summary:
for this laptop with Audirvana+ and IEMs- Wyrd doesn’t really add or detract to GO450 sound qualities or dynamics.
appreciable difference or improvement, none I could tell.
Config #5:
macbook pro USB (Virtue Audio USB cable) connected to Wyrd.
Wyrd to iFi nano iDSD using a Wireworld Starlight 7 0.5m USB cable (nano iDSD powered up after USB cable/power connected. ie. not on battery power.)
Heir Audio 4.AiS
vs.
Config #6:
macbook pro USB (Wireworld cable) connected to iFi nano iDSD (nano iDSD powered up after USB cable/power connected. ie. not on battery power.)
Heir Audio 4.AiS
Findings after much cable back n forth:
Config #6 had a slightly wider and taller sound field.
guitars that felt "in my ear" on config #5, felt slightly outside my ears a bit in config #6.
bass drum hits that were wide and deep in config #5, also seemed a bit "taller" in config #6.
as if the "window frame" of the sound got a bit wider and a taller, without walking closer to the window.
guitar string decays seemed a bit more real (less fuzzy in the final, quiet trail off) in Config #6.
Note:
turning on nano iDSD BEFORE connecting USB cable in Config #6 (thus running off battery)
did not slightly widen/heighten the soundstage as in Config #5.
Wyrd + nano iDSD Summary:
might be keeping the Wyrd in this nano iDSD desk set up, it widens some of the "in the head soundstage" with IEMs and nano iDSD.
hm, wondering if this is what the micro iDSD will sound like?
maybe something to be said for the combo of USB re-clocking AND clean power.
plus Wyrd can be relocated to other USB DACs should they ever benefit, or for those DACs/Amp without a battery for iPad/iPhone usability at the desk.
Discerning Wyrd differences in these setups was harder, took longer to recognize than comparing between DACs themselves (GO vs. nano iDSD, for example.)
no surprise there I guess.
