SSL443
- Oct 18, 2015
Possibly, however if that's true then I am putting my Uber and the 4490 at the same disadvantage so it's a fair fight!
Or, it could be covering up whatever differences there are.
I hope I'm not going too much at a nerdy tangent here and getting even more out of my depth, but do any 4490 owners here use Audirvana+ as their music player? Would you mind sharing the SRC settings you use for the 4490? Or do you have the SRC in Audirvana+ disabled and let the 4490 do all of the oversampling itself? I've always just left SRC to the DAC hardware but a lot of guys over on CA are pretty confident that the SRC capabilities of a computer system are superior to many of those that have been programmed into the DAC hardware. It would of course be blasphemous to engage any software-based SRC on a multibit DAC, but what about a mid-priced delta-sigma model like the 4490? Would that benefit from it or is it still best to leave alone?
Well just ordered a B-Stock 4490, can't wait to see what it brings to my setup! Ordered a Mani too as I was just too curious as to how it sounds.
I'm gonna stick my head above the parapet and conclude that to my ears and in my system, the Uber and 4490 are VERY close sonically. There is a difference, and the 4490 is superior IMO, but boy you need to concentrate hard to hear it. This is not to be taken as a negative. I *really* like the sound of my Uber, and I really like the sound of the 4490, both are excellent sounding DACs. If I didn't already own a Uber then the 4490 would be the no-brainer choice. Even as an upgrade for Uber owners it's excellent value. But if my goal is to climb the sonic ladder then I'm realising the 4490 is more like a sideways step in my situation. I think I'm destined for multibit...
IMO, multibit, at least the Bifrost, is also a side grade rather than upgrade. Then again, your ears will tell you if it's really an upgrade or a side grade.
Yeah I asked some folks in the HE-560 thread how the multibit improved things, a couple said it wasn't really worth the money and it seems some people even preferred the 4490. At that point I decided I wasn't confident that it would be worth an extra $200.
I'm also way less sensitive to amp/DAC gear changes than most folks here.
Yep...I think there are two options here.
1) Your system isn't going to pick up the differences and a MB isn't going to do much to change that. So, you can either chill with the 4490 and be happy or plan to spend significantly more money to find something that will have a real impact. And even if you do spend a ton of money, it's still no guarantee...
2) You're a little bit DAC-deaf. This would be FANTASTIC news. Spare your wallet, sit back, and enjoy the tunes.
