AudioProm
is there any easy way to trim down the volume a bit?
Reduce the system volume or run Equalizer APO to reduce gain level.
Sadly (at least on Mac OS), the Unison USB adapter shows up as not supporting system volume, so my computer disables volume controls. Same thing when I select the DAC as exclusive use in Tidal - it detects that it doesn't support volume and disables Tidal's volume control as well.Reduce the system volume or run Equalizer APO to reduce gain level.
Not a Unison USB issue. It is what Tidal does and the same thing happens with any other DAC. Turn exclusive mode off so you can turn down the volume, or use something like iFi IEMatch which is designed exactly for this situation.You should write to Schiit support and find out if this behavior is normal. They probably want to know which MacOS version you have and any lighting / USB dock if you're using one.
Ah, interesting - it's both a Unison and a Tidal issue. Setting it to not use exclusive mode does indeed let me turn down Tidal's volume independently which is useful. Alas the system volume is still set static, so for apps without their own in-app volume control, I'm stuck with the really, really high volume. Thank you for the fix on Tidal at leastNot a Unison USB issue. It is what Tidal does and the same thing happens with any other DAC. Turn exclusive mode off so you can turn down the volume, or use something like iFi IEMatch which is designed exactly for this situation.
Update: SoundSource is perfection! It allows system-wide, and per-app volume control, as well as routing different apps to different sound devices if they don't support it natively like Tidal or Audirvana does. I can't hear any degradation in quality, and now that I've set the master volume for the Bifrost 2 device to ~50% volume in SoundSource, I can take full advantage of the Asgard 2's volume controls. You can also set per-app effects and EQ, although I haven't messed with that stuff much as I usually prefer flat EQ....I might also experiment with SoundSource which someone else mentioned as a potential way to control different devices/apps volumes on a Mac, although I have no idea if it reduces sound quality or not.
If you are talking about connecting the DACs to each other, no that won't work. Neither of them have analog inputs. Only outputs.I have a question I hope all you experts can answer for me. I have a bifrost 2 coming and I will connect it by spdf to my computer. I have another bifrost multibit that i want to run beside it. Can I connect the second dac with xlr to rca cables.Both will have a Lyr 3 on top of them. Is it ok to chain them together like that?
You can use two DAC's with one amp using something like the Schiit SYSI have a question I hope all you experts can answer for me. I have a bifrost 2 coming and I will connect it by spdf to my computer. I have another bifrost multibit that i want to run beside it. Can I connect the second dac with xlr to rca cables.Both will have a Lyr 3 on top of them. Is it ok to chain them together like that?
That is the way I'll go I guess. Just need the 2and lyr 3 and then I can have the input to both to do some testing fun. By the way been having fun listening to some British Big Band stuff.. Quality on them are special.Assuming RCA S/PDIF coax out, have you tried RCA splitter cables to Y off of the computer to the 2x DACs? A Schiit SYS switch will also work as 1-to-2 or 2-to-1 switcher since it is fully passive.
