magicalmouse
I want to use the pre-amp out as a line out, what volume should i set, my amplifier has an input sensitivity of 300mv.
thanks
d
thanks
d
you start at 0 and you dial up until your ears tell you its okI want to use the pre-amp out as a line out, what volume should i set, my amplifier has an input sensitivity of 300mv.
thanks
d
you might also set the Asgard 3 to low gain first. depending on the analog source / DAC driving the Asgard 3, high gain setting may be too sensitive on the volume knob before it gets too loud.I want to use the pre-amp out as a line out, what volume should i set, my amplifier has an input sensitivity of 300mv.
thanks
d
Agreed. And if anyone asked I would say pass on the internal DAC and go external with its own power supply.I think that the Asgard 3 sits in its own little niche.
The dedication of, and the quality of, a power supply in a DAC is critical to musically coherent conversion of ‘digits’ to ‘waves’.Agreed. And if anyone asked I would say pass on the internal DAC and go external with its own power supply.
Yep I agree. And to my surprise I have been recently experimenting with passive signal ground filtering on a Jotunheim 2 and a older NOS R2R DAC and holy crap, the level of performance jump I would not of believed until I heard it.The dedication of, and the quality of, a power supply in a DAC is critical to musically coherent conversion of ‘digits’ to ‘waves’.
I own a Asgard 3 and a Jot 2. They powered a pair of Audeze LCD-XC (2021 model). If using SE out in high gain, using EQ I may prefer the Asgard 3. Although very similar in tonality, the Asgard 3 has more headroom in SE mode. When using balanced out the Jot 2 wins for me and is what I am currently using. With both amps I was using a Modius DAC (AKM 4493) and then my older NOS R2R Proceed DAP DAC. With both amps in SE mode the presentation is warmer than Jot 2 balanced. This difference in tonality can be balanced with cables, EQ or tweaks. Just my 2 cents and experience with both amps.After upgrading to the LCD-X, I found the Asgard 3 warmer than my audio interface (Focusrite Scarlet). The mid to upper bass seems more present on the Asgard. Also, the soundstage is less precise but broader. Instruments are bigger and more enveloping. I also found the attacks and transients to be calmer and more relaxed. Now I want to try a more analytical headphone amp to compare. Maybe a J2 is up next since I could just swap out the DAC card between the two units.
How do you feel about the dynamics and transients between the two? You're right, there are many approaches to altering the tonality, but very few ways to change the dynamics. I also wonder how the changes in tonality occur when SS amps are always measured extremely close to flat. It's one of those things objectivists say is placebo but most who have been in the hobby for a while have heard these differences without a doubt.I own a Asgard 3 and a Jot 2. They powered a pair of Audeze LCD-XC (2021 model). If using SE out in high gain, using EQ I may prefer the Asgard 3. Although very similar in tonality, the Asgard 3 has more headroom in SE mode. When using balanced out the Jot 2 wins for me and is what I am currently using. With both amps I was using a Modius DAC (AKM 4493) and then my older NOS R2R Proceed DAP DAC. With both amps in SE mode the presentation is warmer than Jot 2 balanced. This difference in tonality can be balanced with cables, EQ or tweaks. Just my 2 cents and experience with both amps.
There are differences between the two. For the money I think the Asgard 3 is a stellar SE performer. Jot 2 IMHO is a better amp, especially if you go balanced and scale the other parts of the system. There are many tweaks that will improve the performance of the Jot2 to take it to a whole other level. The Asgard 3 will benefit from the same tweaks but will not scale to the same level of the Jot 2. Of course, YMMV.How do you feel about the dynamics and transients between the two? You're right, there are many approaches to altering the tonality, but very few ways to change the dynamics. I also wonder how the changes in tonality occur when SS amps are always measured extremely close to flat. It's one of those things objectivists say is placebo but most who have been in the hobby for a while have heard these differences without a doubt.
