tincanear
Would you guys say the Asgard 3 is a decent upgrade over the atom stack? And if so, should I get the multibit dac card or just use my atom dac with it? Been looking around for something not quite as neutral as the atom and I think this might be just the thing. Any input is appreciated.
Welcome to Head-Fi and this thread. Is there a particular aspect of the Atom stack's sound that you are looking to improve on? what model(s) of headphones are you using / planning to get in the future?
Asgard 3 is a really good amplifier, with both power and resolution; capable of driving anything from IEMs to full-size dynamics (Beyer, Senn, Focal) to newer full-size medium efficiency planars (e.g DCA and HFM).
If you are comfortable with self-installing a multibit or other DAC card in the future, I would just order the A3 without a DAC module and use with your Atom DAC for now.
Note that current Schiit DAC Modules (that fit inside Asgard 3, Lyr 3, Jotunheim 2, etc.) only have a single digital input (namely USB2.0) and don't have RCA coaxial, toslink optical, etc. inputs. If you are using those non-USB interfaces, then look at a Modius (presently AKM 4493-based) DAC to stack under A3. Alternatively, I'm guessing that some additional DAC models using ESS9028 series are under development and will be available 2nd half of 2022.
