Originally Posted by pp312 /img/forum/go_quote.gif
This thread is something of a mess in terms of advising the OP. Phrases like the 650's "suck" certainly don't help, but the real issue is some saying the 650 is much harder to drive and others saying the 600 is harder when it seems clear from the figures that the latter is the case. Can no one clear this up definitively?
If money is not an issue (which would be the case in an ideal world lol), then the solution is just to make sure the amp used to power the phones is within the range of the impedances (of course we have to factor in certain amp characteristics to optimize the efficiency of the power use, but thats beyond the scope of this). We have to remember that the headphone's sensitivity is also important because it plays a factor in how "easily" the phones can be driven.
Point is, headphones will sound different depending on what is linked to them. The only control here is that the mechanics of the headphone /itself/ will never change, only the equipment connected to it will change the sound.
Therefore, by design, just by looking at the figures, if powered properly by an amp that colors the sound as minimal as possible, the HD650 "should" have more impactful bass because of the area under curve between the HD600 and 650 in the bass range. However, because the HD650 is more /sensitive/ than the HD600, it may be more easily driven by a source compared to the HD600 in certain frequency ranges (NOT necessarily in general).
If you want a /true/ definitive answer of what will sound better, the only real way is to put them side-by-side with the same equipment (or better yet, whatever application you're going to use them for), and listen to them. Listen to them with a properly powered setup to be able to distinguish... try them out.
There's more than just numbers and figures because sound is different for everyone.
However, one could read the hundreds of posts about the HD650 (from users who were also HD600 owners/users) sounding more powerful with the bass compared to the HD600. The graphs can give a partial explanation to that because of the design. Clamping pressure due to a person's head (which could increase the effect of bass) and all those things on the other hand aren't useful metrics if you're making a product cause they vary too much.
