linnmaster
- May 21, 2009
It's not that I don't think the PS gets very hot, I know it doesn't. Why is there the assumption that foam here is like petrol? I guarantee you could not start a fire with a spark with this foam. As a matter of fact, before I posted back, I took some of that foam and put it in the direct path of an electrical spark, imbedded in the foam by short circuiting, and there is no fire. Puting it in the line of sparks from a grinder produces no fire also. I think I may have to light it up to get it burning. I didn't light it up.
I wouldn't be able to come to a meet with that thing anyways unless someone gives me a hand carrying 100kg of preamp. So, I think you are very safe there
You seem to be stuck on the idea of using pipe clamps to secure them. I think if you saw the way things are in the actual unit, you will understand that you cannot make it work. I could easily get rid of the foam and cut bits of timber and pack them in there to prevent the caps from moving. Actually, timber is also flammable also, and a spark might set that alight too, so some steel would be more ideal, or aluminium ....
I don't find the safety side of things funny. What I found funny is ... Could you imagine the look on my neighbours face if I knocked on their door and asked the question if it would be OK if I continued to have this foam inside a power supply for a stereo ....?
Originally Posted by manaox2 /img/forum/go_quote.gif I know you don't think the supply gets very hot, but a spark is enough to start a petty quick and intense fire regardless. So sincerely, please do not ever come to a meet with that thing. Your negligence in sticking foam inside of a power supply rather then buy some cheap pipe clamps available at any local hardware store astounds me. I really don't find it very funny. |
