SASH Deux & Tres; impressive planars from Ukraine
Jan 15, 2025 at 8:02 AM Post #1,351 of 1,462
I suggest not to get your hopes up too high if you are a bass head because the sash tres has neutral bass in terms of quantity, everything else is exceptional, especially the way they resolve the mids. But you can always use the eq to boost the bass and you can see some users using the tres with eq with satisfactory results.
That is only a positive thing. Sash's bass level is just spot on.
And quality is top tier.
No need for eq. 👍
Edit:
I have Fiio FT1 if i want elevated bass.😁
Jan 15, 2025 at 6:58 PM Post #1,353 of 1,462
Anybody can compares to Edition XS?
The Tres SE is decidedly better. More resolution, more natural sounding, better bass, more heft to the sound.
Jan 15, 2025 at 7:43 PM Post #1,354 of 1,462
Way better quality too.
Jan 15, 2025 at 9:28 PM Post #1,355 of 1,462
Anyone compared to the Arya Organic or HE1000 Stealth?
Jan 15, 2025 at 9:48 PM Post #1,356 of 1,462
I own the Arya V2 and the HEKSE. The Tres SE is easily on par with the Arya. Coin flip on that one depending on one's taste. The HEKSE beats it on resolution and the technicals, but I like the Tres SE more subjectively.
Jan 16, 2025 at 7:42 AM Post #1,358 of 1,462
Jan 16, 2025 at 9:13 AM Post #1,360 of 1,462
Jan 16, 2025 at 9:14 AM Post #1,361 of 1,462
Jan 16, 2025 at 9:51 AM Post #1,362 of 1,462
Bass quantity and extension is better on the Tres SE?
The biggest difference is that the Tres SE has substantially more impact and fullness to the bass. This gives the bass much more presence than the graph would seem to indicate. Extension is the same really, but I find that I can listen to the Tres at higher overall volumes (and thus get a bassier sound) because the treble is not as elevated as on the XS.
Jan 16, 2025 at 11:36 AM Post #1,364 of 1,462
I can confirm that. In my opinion Tres SE does not need eq at bass.
There's good amount of impact, fullness and punch at the bass.
Jan 16, 2025 at 12:27 PM Post #1,365 of 1,462
Question for any of you that might know:
On the Sash website, in the list of color choices for the Tres SE, there's a selection for "wenge". Does that actually use wenge wood, or is it just wenge "colored"?
