Just got myself this same combo, where'd you get the short cable?
Thanks!
Thanks!
Id like a link to that cable as well. I need to hook up the s4 to the fiio e17. Will this DAC/ amp make a difference listening to the S4 through my V Moda crossfade 100's????
What is the best/easiest way to put music on the Galaxy S4?
Thanks.
any sound improvement using usb dac instead of the simple jack?
If you mean USB DAC + AMP then yes.. always
No point using an amp with headphone out?
And what about fiio e07k vs e17?
I will only use it with usb otg no optical or coaxial, thanks
Sent from my GT-I9505 using Tapatalk 4 Beta
Yep unless your listening habbits are such that you cant get enough volume from your S4, no amp required. I've been using my TF10's daily and rarely go over around 60%.
