obsidyen
It will be a real shame if S6 has subpar audio quality.
As with every Samsung Exynos phones,it comes with a Wolfson DAC. S6 comes with WM1840.
https://plus.google.com/+supercurioFran%C3%A7oisSimond/posts/Zs5voZXCFde
Still Touchwiz Resamples 44.1KHzto 48KHz.
https://plus.google.com/+supercurioFran%C3%A7oisSimond/posts/BpAbw9SpyBX
And what about the Note Edge?
How good is it with audio quality and volume?
Hi, there. Got my Note 4 910C (exynos) yesterday. I Upgraded to android 5.0.1 just after initial setup and installed everything I used everyday on my SGS3 (which was rooted and used with AOSP omnirom + Boefla Kernel). From this morning I started testing audio quality on my Sennheiser IE7s and Rocket Player (flat EQ) - my choice for Android music playback. Sound quality seems really good, I didn't notice much difference compared to what I had on SGS3+IE7: bass is warm and slightly dominating, vocals are clear, instrument seperation good, soundstage quite wide, volume level for listening outside is 1 notch after the sound warning, inside 2 below. I'd say Note4 with exynos is on par with my SGS3 in terms of sound quality. I'm happy id didn't turn out to be a disaster!
Oh good, I was beginning to think there were no Sprint or Verizon customers on here, since basically nobody else but Poland and Korea have the Lollipop update yet. You have an Exynos handset, which means a Wolfson DAC, so it should be decent. Mine is a Snapdragon and I'm not 100% happy with the direct audio out (not bad, just aggressively average), but then I prefer to use the phone as a transport anyway. Which leads me to my earlier question from my previous post:
Have you plugged your phone into a DAC? If so, when playing a 44.1KHz track, does the DAC show the same figure, or 48KHz? From what I've heard, this forced sample-rate connversion was supposed to be gone in 5.01 but I can't find confirmation now that it's actually out. Would make USBAudioPlayer obsolete if so, and finally let us use any player we want, even free ones. Would be nice to get bit-perfect digital out from stuff like Jremote/Gizmo, etc.
I thought the US variants were Snapdragon not Exynos based SoC so I don't know how the USB drivers of the Lollipop implementations would compare.
I'm not from the US, I'm from Poland . I do not have a DAC, never used one actually, but if there is any other way to test I can try it. Do you know of any app which would show the audio-out frequency from the micro-usb port?
The SoC is irrelevant to this, it's a software difference. The Android mixer would forcibly convert everything to 48KHz internally in pre-5.x.x, and then would only output at this rate regardless of source sample rate. Lollipop is supposed to add support for multiple sample rates internally so any rate can come out untouched. Apparently the fan-made images for Note 4 do indeed work like this, but I don't have word yet on whether the official Samsung ROMs do too. I'd assume they would, but there's no guarantee with Samsung about sensible choices being made. Look at Touchwiz bloat and lag.
Exynos vs Snapdragon is only a concern if listening through the device headphone jack, because the Exynos models have a separate, competent DAC chip (Wolfson), whereas the Snapdragon designs use the integrated DAC solution on the Snapdragon SoC, which has noticably lower performance (but saves the cost of the extra chip, which is probably only a few cents). It's not all bad news, though. The Snapdragon models are all-around faster overall, and have significantly better graphics hardware, plus if you're using a portable DAC/amp solution, the internal DAC in the phone is irrelevant anyway. I'm glad I have the Snapdragon, personally, but I wouldn't complain if they put the Wolfson DAC in it too so both models sounded the same through headphone out, even if it cost $10-20 more, since this is the way most people will use them...
Like I said, different implementation of the ROM's for each SoC, so one never knows what's in the soup. If you're looking for hires, be prepared for possible/likely disappointment (I hope I'm wrong).
Supposedly Samsung has toned down their heavy/inefficient hand on TouchWiz. I use Nova Launcher any.
Wolfson doesn't mean that every model of DAC chip they make is magical or that Qualcomm blows.
