Salvagable parts inside a stereo?
post-222639
Thread Starter
Post #1 of 9
dokebi
I have a broken 5disc changer sony stereo and I was wondering if there are an salvagable parts inside that would be useful. I know that the volume assembly knob is from ALPS.
post-222764
Post #2 of 9
braillediver
Rip it open and look? Probably not a lot of usable parts though. Maybe the RCA's or transformers or knobs.
It'll probably be very unit specific though so unless you're going to fix a similar player there might not be much of any use.
But it's always fun to look.
post-222846
Post #3 of 9
Budgie
Never looks a gift amp in the jackhole.
Power supply & transformers, capacitors, opamps, volume pot, are all worth thinking about.
post-222878
Post #4 of 9
rickcr42
Are YOU talkin' to me?
heat sinks
post-222910
Post #5 of 9
dokebi
I desoldered all those parts perfectly.
Now if I can only find a use for them. The power is heavier than my computers 400watt antec.
The biggest were 4 ELNA caps, 2 4700uf 25v and 2 3300uf 50v around the supply.
post-223471
Post #6 of 9
Budgie
I am guessing you would have all the parts for a headphone amp, if you want to DIY one.
post-223527
Post #7 of 9
dokebi
What would I use for the pcb?
post-223545
Post #8 of 9
braillediver
Perf Board. PCB material with uniformly spaced holes. Plated or unplated
Heck you could draw out the circuit on a peice of cardboard and connect all the parts.
post-224189
Post #9 of 9
Budgie
You can get perf board at radio shack. Unfortuneatly, the boards they have with copper traces don't seem to take solder well, but they can be used also, if you clean the copper well, before soldering.
