donunus
- Nov 12, 2004
Its all relative. the k1k is less able to be powered by a portable than a hd650 but still much better than most speakers. Its not in their sensitivity that make them headphones or speakers, its in their usage. About lying in bed, it's all subjective to what one person finds comfortable to lie down with. I can lie down with bookshelf speakers if I want but I don't because these spkrs sound best on stands while the k1ks still sound best on your head/ hence the word "HEAD"phones
Originally Posted by fewtch How are they when you want to lie down in bed and relax... can you throw them on and take them off in 1/4 seconds like you can with most headphones... can you use them in a library or on the bus like you can with IEMs or closed cans... can you plug them into a CMOY or PCDP if your normal amp is being serviced or is elsewhere... They are just as convenient and easy to use as a pair of Senn HD650s? Why don't I believe this? All it takes is a single picture of them on someone's head to know they require some adjustment, and could not reasonably be used at work in a cubicle or in a library (where HD650/K701 definitely could, as long as the volume is kept low). |
