Super-Gonzo
- Jul 1, 2003
With the recent building of a PPA, my desk is really more of a soldering station at this point
![wink.gif](http://www.head-fi.org/forums/images/smilies/http://hfimage.head-fi.org/smilies/wink.gif)
Originally posted by Super-Gonzo I found an interesting white paper from an EE's website. They cover his thoughts on optical vs. coax digital connections... Perhaps all the $$$ hi-fi companies are trying to convince us of the reverse because there is no money in an optical solution... |
Originally posted by Cacophony I do have a pretty nice DAC: the Musical Fidelity A324. Got the squeezebox yesterday, finally got it to work with FLAC today (not a pleasant experience, please be aware that for all the hype we're on the bleeding edge here). Tonight I discovered what people had been talking about when they say "soundstage" and "imaging". Even though the A324 is supposed to have pretty impressive anti-jitter circutry, reclock the signal, yada, yada, the difference is astonishing. |
Originally posted by Music Fanatic So are you running the Squeezebox through the DAC or are you using the built-in DAC in the Squeezebox? |
Originally posted by Cacophony I'm currently running the squeezebox through the DAC via the squeezebox's optical out. The improvement that I'm describing is over my prior transport, which was also connected to the DAC via optical. There's a coax out on the squeezebox that I'll experiment with soon as well. I'll also try comparing the internal DAC with the A324, but I've found in the past that the A324 has slightly higher output gain that makes such direct comparisons difficult to make. |
Originally posted by Music Fanatic That's great. May I ask, what was your former transport? I think the Squeezebox has fine components inside, but I'm impressed to hear that you noticed such a large difference. |
Originally posted by Super-Gonzo I've pre-ordered a RokuLabs SoundBridge M1000, (the smaller model.) It should be here by the end of the month. Are there enough interested head-fier's out there to justify a review of the unit once it gets here? |
