emericanchaos
- Dec 13, 2006
my soundcard only has 1/4" balanced outs. would it be possible to feed say the heed canamp with a 1/4 to RCA
Originally Posted by grawk /img/forum/go_quote.gif You need a cable that connects + on the 1/4" to + on the rca, and ground on the 1/4" to ground on the rca. Leave - disconnected. |
Originally Posted by krmathis /img/forum/go_quote.gif Sure. You just need a cable with 1/4" in one end and RCA in the other end |
Originally Posted by emericanchaos /img/forum/go_quote.gif you're saying a regular 1/4" to RCA will suffice? |
Originally Posted by dcheming /img/forum/go_quote.gif Using a TS (mono) 1/4" plug would short out the inverted (-) side to ground when plugged in, which may or may not be a problem depending on how the outputs on your card are designed. Since you're going to make your own cable to be on the safe side I'd use a 1/4" TRS (stereo) plug instead. The tip of the TRS would be connected to the center pin of the RCA plug and the sleeve of the TRS would be connected to the outer ring of the RCA. |
Originally Posted by emericanchaos /img/forum/go_quote.gif according to this page http://www.activemusician.com/item--EM.US35030 my device has "TRS balanced/unbalanced outputs" does this mean a radioshack 1/4" to RCA will work? |
Originally Posted by dcheming /img/forum/go_quote.gif Since they're balanced/unbalanced capable you should be fine with the cable you mentioned. |
Originally Posted by emericanchaos /img/forum/go_quote.gif just for posterity i tried the RS cable on the balanced outs. only plays the left channel. seems to work on the HP out pretty well though. according to m-audio the HP out is rated at .8 volts for max output. the balanced out puts 1.5V and the unbalanced is 3.0. i figure it's safe to use the HP out since it's the weakest of all until i make this interconnect. on topic: to make this 1/4"TRS to RCA interconnect i'm connecting the right chan to signal on the red RCA, left to signal on the white one and i'm shorting the ground to one of the channels? |
