vjcs20
- Jun 16, 2005
Hi guys,
I just received my P-51 Mustang yesterday from RSA. Was using a Tomahawk previously. Firstly, I have to say that Ray has outdone himself with a newer smaller amp but yet at the same time, upping the sound quality a notch.
So I was trying out the Mustang and I really like how it sounded out of the box. If it sounds this good before burning in, I can't imagine how it would sound after 100hrs of burning in.
Anyways, a sudden inspiration came to me. I recalled reading previously how some Xin users were using two Xin Super Macro 3V6s in their portable setup as a pre and power amp combo, and how amazing the dual combination sounded. So I though to myself, why not try something like that with my two RSA amps?
So I plugged in my iPod classic 160gb to my Turbo LOD to the Tomahawk (as pre-amp) to the Mustang (as power amp) to my Triple-fis.
[size=xx-large]WOW!![/size]
Instant music nirvana. The music sounded so real and life-like and present in front of you. I'm not very good with words so please pardon my lack of a better description. But, the sound is really that good! There was so much more details and nuances present in the music & voices that I was taken aback. Listened to rock and jazz, instrumentals and vocals and all sounded so much better than with just the Tomahawk or Mustang alone.
If there's anybody out there with both amps, do try it and see how you find the sound.
Lastly, do note that for the Tomahawk (as pre-amp), I turned the volume knob all the way to max while keeping the gain at LOW. For the Mustang (as power amp), I turned the volume knob to about 10 o-clock.
Hope this helps!
Hope this helps!
