WittyzTH
That's the amp what I want to have. It seems like the Raptor with more power.
Did the AD2000 work well with the WA6? I have AT cans too.
That's interesting. jamato8 have you compared your moded WA6 with the stock WA6SE?
Thanks!
Now I'm quite interested in the WA6 more than the balanced rig since there are quite few choices.
Originally Posted by musicmind /img/forum/go_quote.gif I had the chance to compare the maxxed WA6 (not SE) with the stock Sovtek 5u4g and GE 6de7, alongside the Headamp GS-1, using an HD-650 and ATH-AD2000, and I didnt find the WA6 to be tubey or lush in the stereotypical tube amp way at all. |
Originally Posted by jamato8 /img/forum/go_quote.gif The modified 6 changes the power supply into a dual power supply so each power section of the tube has its own cap, which increases the dynamics and everything else about the presentation. Mine also has Black Gates in Super E configuration, which lowers ESR to almost nothing and does away with inductance. I also use a few teflon caps in strategic positions and a few other changes as well as coming off from the power supply at a different point than that of a modified Woo 6 from Woo Audio. Anyway, get the PDPS if you get one and you will have a fine amp. |
Originally Posted by ldj325 /img/forum/go_quote.gif Here comes a curve--- If you're going to go balanced (I'm a person when it comes to balanced so you will get no objectivity from me on this issue) I think that the RudiStor NX-33 has much higher sound quality that the Headroom. It is just that fewer people have heard then as they slightly rare in these parts. That's my 2 cents. |
Thanks!
