Killercrush
I completely agree with wakeride74 about the source upgrade, an even better amp than the Glite will show your source weaknesses even more.
Originally Posted by trose49 /img/forum/go_quote.gif I have never heard a GS-1 but LOVE my HR-2! Very speedy, liquidy highs and plenty of power. Drives my 600ohm Beyers with ease. |
Originally Posted by recstar24 /img/forum/go_quote.gif . If I had to make the choice now under a different context I would probably go GS-1, as its a bit closer to neutral and more transparent. |
Originally Posted by Asr /img/forum/go_quote.gif Both amps are among the best in the <$1K solid-state arena for sure, but it really comes down to sonic preference and your source, since both amps are designed for high-end sources. Ray builds his amps around a Meridian G08. I forgot what Justin uses but he also uses a high-end CDP. So you should probably upgrade your source before you go for either amp. The amps also have very different form factors and feature sets that you should take into account. The HR-2 comes in two chassis that are relatively compact together. The GS-1 comes in a single chassis, with two inputs, two headphone jacks, a loop out, pre-amp output, and two-way gain switch. On the technical side, the HR-2 is op-amp based on the AD797, while the GS-1 uses the discrete Dynalo circuit. You can roll the op-amp on the HR-2, and the GS-1's modules are upgradeable for when HeadAmp later releases new MOSFET modules. On top of all that, you can order one in either silver or black, while the HR-2 comes in only black. I haven't heard an HR-2 yet, but the GS-1 is a transparent amp that does the job of acting a window into your source very well. The people who complain about its sound usually haven't heard it with the right source. I'm sure the HR-2 is an amazing amp no doubt, but since I haven't heard one yet I can't comment on it. euclid posted a comparison between it and the Apache a while back and said that the HR-2 is pretty close! The HR-2 has also been out for several years now so just dig back into the past and you'll find a bunch of reviews and impressions! |
Originally Posted by Ray Samuels /img/forum/go_quote.gif The HR-2 has op-amp in the gain/input position but it is a full discrete circuit as a driver/buffer. Ray Samuels |
Originally Posted by nfusion770 /img/forum/go_quote.gif I tend to agree with most of what has been posted about sound sig- HR-2 a bit warmer, the GS-1 more analytical. When I was trying to decide between the 2 I kept the HR-2. Then again I eventually sold the HR-2 in favor of the Opera, so if you can stretch your budget a little I'd definitely consider the Opera. Both the GS-1 and HR-2 are excellent amps, however, and are pretty similar overall IMHO. |
