funch
I've always wanted to hear a B22, and figured the only way was gonna be to build my own.
Power supply
It sounds great, and is dead silent. Just burning it in now and making sure everything is working as intended.
I was curious where you picked up the transformer for the switch circuit. I bought one of the mounting boards, only to discover that
the trannies for them were unavailable. Thanks.
Hi Funch, thats a nice build. I like the unbilical and the cases. Where do you get those umbilical plugs and how many poles are they? How bot the cases, are these from ebay?
Funch can correct me if I am wrong but the cases look like they are hammond cases (you can find them on mouser, digikey and the whatnot).
The ambilical cord are called speakon connectors and they can be found at redco.com I believe they also have something called powercon which is also similar. (both quite expensive for connectors as they where made for heavy duty dc use). I honestly just suggest using something simple like a 3pin xlr. Much cheaper connectors and works just as well. Just make sure that you don't mix the connectors up with your balanced input (if you plan on using such a thing.)
Hi all,
I'm seriously considering building one of these. The only DIY I have under my belt is some cables and a Project Solstice kit. Do you think something like this is too much to take on at this point? I think the soldering doesn't look too complex -- it's mostly the wiring, mounting, and various options that intimidate me. I suspect that if I take my time and plan everything exhaustively, I should be able to pull it off.
Zashoomin, you should know that I was partially inspired by your chat with Tyll. I'm bummed that I didn't get a chance to listen to yours at CanJam.
Random question (pre pre planning): You have a Balanced and SE port on the front. Are you doing the 4 board thing where you can also do two SE amps (and then just doing one SE amp)?
Thanks!
Hi all,
Let me first say that I am a big fan of Beta22 and it is a bit sad to see that it is under-appreciated. I feel that Beta22 has a sound that offers tube liquidity like the best Krell amps which is very refreshing since most modern amps that I had tried sounded cold and mechanical, all details and technicalities but no soul.
