haejuk
- Dec 4, 2003
That does make sense. I was wondering why it only had 3 contact points. I guess I am back to the start for the power switch search.
Can anyone answer my noobie question? How much would all of the parts for 3 boards cost?
jcx - are you saying 2x beta22 + 2x sigma22 is better or worse than 3x beta22 + 1x sigma22?
Let me get this straight. The dual mono design assumes you have a PS board for every amp board correct? This would mean 2 beta boards and 2 sigma boards.
A fully balanced build means you would have 4 beta boards and 2 sigma boards, correct?
Yes if choosing to use the "customary"/"default" PS to power them (σ22).
That's one option but a single σ22 will power a 4-ch / balanced β22 for headphone duty.
the signal gnds are usually still connected in the source, so mains-sec leakage current can still flow in the signal gnd path - use split bobbin ps xmfr with lower parasitic C than toroids, heavy shield braid coax for signal IC, or balanced input with pin 1 gnd carrying the leakage current
Thanks jcx.
Can you please explain this bit? Which transformers are you talking about?
