Nayyte
Okay I think I could be experiencing burn in mania for the first time. My RH-5 has been on all day for the past 11 hours keeping those tubes warm. I really feel like I am hearing more of the headphone qualities that I remember and not the amp messing things up like before. Still only listening to the LCD-2, gain 1 vol. 76. Vocals are forward and the bass has tightened up some. Drums got pushed back, all things I like. Still hard to tell where this will go. I suspect this is all just tube conditioning and these GE Grey plate O-getters just need some long burn in time as per the norm. Starting to dig this amp. I have it hooked up to my active adam t5v's and they sound nice, though I wish there was a pre/head selector on the amp. Switching the individual speakers off is the only way to disable the pre-out otherwise it plays both headphones and the speakers. Also if I want to go back to speakers only, switching them on doesn't enable the pre-out of the rogue; if there isn't a headphone plugged in while I switch on the active speakers, the rogue won't output. I guess you have to mute the audio, then turn on the speakers, play the music through both outputs, then unplug the headphones. There should be a toggle!
Oh I forgot to mention that my particular RH-5 was an early run unit and the seller had just gotten it back from Rogue to update it to current specs. Not sure if any caps/resistors were replaced but that would explain the negative experience I was having sorta. I could have been hearing the raw from the factory sound.
This album was fatiguing this morning but not it's gripping me right and putting me in the mood
